Joining the Pack!
/ Joining the Pack! #11
<font color="blue">I am interested in hearing from anyone with a Kioti Cab unit and their experiences. Will be pulling a 7ft International Machines mower, 7ft box Blade. Have R4 tires. Would like a root grapple, or tooth bar set-up, top-n-tilt unit for the box blade, but need to sell the other tractor first.
</font>
I have ~560 hrs on my DK55C, bought new in July '04. I could not be happier with the tractor or its' capabilities. I have used it to restore a circa 1740 farming operation: restored 10 acres of fields, rebuilt over 2k feet of stone walls (i STRONGLY recommend a grapple; i recently purchased a unit from Loflin Manufacturing and i'm very pleased with the performance). I've done more with this machine than i could have imagined..
Don't worry about the cab. I also use mine for logging. I've used it extensively in the woods of New Hampshire (50+ cords of woods) on a variety of trails (read that: some barely wide enough for the tractor).
Couple of things about the cab:
- the A/C unit is STRONG. you could hang meat inside without spoilage. the unfortunate side effect of running the compressor in such a small area is how dry the air gets inside the cab (helpful that there are 2 cup holders). you will get cotton-mouth!
- if you're logging, purchase the grill guard and don't forget to turn your mirrors in when you're on tight trails in the woods (helps to prevent limb snagging).
- visibility with the cab is less than ideal - you'll get used to it.
i would have to say that this machine has exceeded all expectations. the biggest concern i had prior to the purchase was reliability - definitely not a problem with the amount of hours i have on this machine.
good luck
pf
/ Joining the Pack! #12
<font color="blue">Also, not sure I understand how the two sets of remotes work or what the benefit is. One set has 'float' and the other detent only??? I'm getting a 7ft box blade. And the rear electric plug - what is that for?</font>
the remotes (assuming you're talking about the ones in the rear) are for implements that use hydraulics (e.g., backhoe, etc). i strongly suggest getting 2 sets of rear remotes when you purchase the tractor. you'll always find a use for them.
the rear electric plug can be used to hookup trailer lights - frankly, i'm using mine to run the blender /forums/images/graemlins/wink.gif
/ Joining the Pack!
</font><font color="blue" class="small">(
good luck
pf
)</font>
Could you tell me more about the grapple and how you have it hooked up and controlled? I do have what I think are the standard two sets of remotes in the rear. One is listed as having the "float" function and the other only "detent". I think I want to get a grill guard anyway - just not sure how or if there is a problem mounting with the Rhino loader.I'm 6'2" so visability issue may be even worse. I'm glad to hear about the reliability - There is a lot of standard equipment on these machines - I don't know what else I need - I would like more info on your grapple set-up cost and how you use it.
/ Joining the Pack! #14
<font color="blue">Could you tell me more about the grapple and how you have it hooked up and controlled?</font>
the loflin root grapple (~$4,000 installed) is a quick attach implement that is plumbed into the rear remote. the FEL hydraulics allow you to raise/lower/rollback. to open/close the grapple, i operate the port controls (A/B/C/D depending on which remotes your're using). a few pics are worth a thousand words, so i'll post the pics i have ASAP.
this is NOT an ideal setup. i have seen other setups that attach a switch to a FEL control that allows you to open/close the grapple; this would make it much easier to use.
i've used the grapple for:
- moving logs/cordwood
- moving rocks
- ripping roots out of a field (i recently reclaimed a 4a field); the grapple was perfect for removing the layer of peat/roots that the disc ripped up.
i'm constanly finding more uses for the grapple, and consider it to be one of the most useful restoration tools i have (althought the BH is a close second).
i'll post a pic of the grapple shortly.. i'm up to my rear end in planting @ the moment.
pf
/ Joining the Pack! #15
I've got a dk55c with a grapple. Mine has a button on top of the fel stick. It controls a valve that redirects hydraulics to open/close the grapple. It works very well. I've got a WR Long grapple - I'd recommend getting a strong one - mine is a bit bent but has taken a real beating.
As for the cab, I've busted off the antenna round about the first week or two. I'd also get a grill guard. I've smashed in my grill and broke the headlight. I've tried to buy one twice, but the dealers never had one and I never managed to get one ordered... you better if you get a grapple or do much bucket work.
The cab is nice and I'm your height, so visibility is okay. I have four rugrats, so I'm really paranoid there - especially since the hearing is limited with a cab and the radio going...
Enjoy!
/ Joining the Pack!
Got my first look today.
Here is a link to some pics DK55C Loaded
Looking forward to some seat time.
Thanks for all the advice.
There is also a link to some AGCO and Deere Eqmt(in transit the same day as the Kioti)
2017 ADDCO ROAD SIGN DH100-ALS (A60736)
2017 ADDCO ROAD...
2006 Freightliner M2 106 Terex Hi-Ranger HR46M 46ft. Insulated Bucket Truck (A60352)
2006 Freightliner...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Sdlanch SDLD25 (A60463)
Sdlanch SDLD25...
Kubota RTV X1140 (A60462)
Kubota RTV X1140...
2021 Deere 75G (A60462)
2021 Deere 75G...
