John Deere
/ John Deere #1
Russ5160
Where is the factory spot to put a block heater in this engine? Pictures would help if you have any.
/ John Deere #2
Knowing what engine would probably help too. ;)
/ John Deere
[emoji[emoji6][emoji6]]" data-quote="Russ[emoji6][emoji6][emoji[emoji6][emoji6]]" data-source="post: 0" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">
I’m sorry. The engine is a [emoji[emoji6][emoji6]][emoji[emoji6][emoji6]]. It’s not on a tractor. It’s connected to GEHL mixer.
/ John Deere #5
I’m sorry. The engine is a [emoji[emoji6][emoji[emoji6][emoji6]]][emoji[emoji[emoji6][emoji[emoji6][emoji[emoji6][emoji6]]][emoji[emoji6][emoji[emoji6]]]][emoji[emoji6][emoji[emoji6][emoji6]]][emoji[emoji6][emoji[emoji6][emoji[emoji6][emoji6]]][emoji[emoji6][emoji[emoji6]]]]][emoji[emoji6][emoji[emoji6][emoji6]]][emoji[emoji[emoji6][emoji[emoji6][emoji[emoji6][emoji6]]][emoji[emoji6][emoji[emoji6]]]][emoji[emoji6][emoji[emoji6][emoji6]]][emoji[emoji6][emoji[emoji6][emoji[emoji6][emoji6]]][emoji[emoji6][emoji[emoji6]]]]]. It’s not on a tractor. It’s connected to GEHL mixer.
Im glad I aint the only one that has this happen when I post.
/ John Deere
[emoji[emoji6]]" data-quote="tacticalturnip" data-source="post: 0" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">
Might help to post the tractor model. (y)
It’s a [emoji[emoji6][emoji6]][emoji[emoji6][emoji6]] John Deere diesel engine and it’s hooked up to a GEHL mixer.
/ John Deere #7
Try just posting without replying and spell the numbers
/ John Deere #11
/ John Deere #12
It’s a John Deere engine forty thirty nine
4039=4 cylinder engine manufactured in Dubuque, Mannheim or Saran factory. One should be able to remove a hex plug on LH(drivers side) & install a block heater part #DZ102076 similar to photo below.
/ John Deere #13
Might be a matter of finding the right pipe plug to get an external water heater plumbed in to circulate cooling fluid.
Here is a schematic that shows such a plug (key #28) in the block linked to the JD parts site.
Another thought is to maybe contact this fellow who put a video up on his rebuild of a 4039 engine.
Or
4039 series engine & 3043 tractors do not share the same engine family but from viewing the last photo you posted the engine coolant heaters are located in similar locations. Model 3043D utilizes 1.6L Yanmar engine
/ John Deere
Thanks
2018 International HX620 Quint Dump (A62613)
2018 International...
2007 MACK CHN613 6X4 T/A DAY CAB TRUCK TRACTOR (A59909)
2007 MACK CHN613...
2015 MGS GODWIN CD150M PORTABLE DRI-PRIME (A63276)
2015 MGS GODWIN...
New/Unused Wolverine 84in Dozer Blade/Snow Pusher (A65583)
New/Unused...
2024 DODGE TRUCK BED (A65643)
2024 DODGE TRUCK...
2006 John Deere 6420 (A64126)
2006 John Deere...
