John Deere X495
/ John Deere X495 #1
kvlt1
Need info on how to disconnect the reverse safety switch that engages while using snowblower attachment? Any help greatly appreciated
/ John Deere X495 #2
I assume you talking about disabling the RIO option? I just did this on my Dad's X495.
Here's the Deal:
Under the RT foot rest, inside the frame, there's a rod that runs from the reverse pedal to the hydrostatic rear end. On the FWD end of this rod, JD installed a metal bracket which is held in place by 2 jam nuts. When the reverse pedal is pressed, the metal bracket activates the RIO switch.
Crawl under the tractor and remove the rod... it has a pin/clip at each end (long needle nose pliers make it a lot easier). Then simply remove the metal bracket and re-install the rod... and RIO is gone.
Whole process takes about 15 mins if ya work slow.
/ John Deere X495 #3
I have a LX279 and what I did is I follwed a the metal rod to the back of the tractor and found the switch that it is connected to. You adjust the switch so that can use a slow reverse and the PTO won't stop. The other choice is to remove the switch all together and jumper the switch out which what I did. Without the jumper the PTO will not engage.
UNUSED (2) 3" HYD CYLINDERS (A62130)
UNUSED (2) 3" HYD...
Arrow Quip 7500LMR Cattle Chute w/ Head Holder (A64047)
Arrow Quip 7500LMR...
43024 (A59228)
43024 (A59228)
2021 VOLVO VNL860  6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2021 VOLVO VNL860...
500 GALLON FUEL TANK (A62131)
500 GALLON FUEL...
STORAGE FEES (A59910)
