John Deere TRS24 Snow Blower
   / John Deere TRS24 Snow Blower #1
mrouster
My second stage gets snow behind it and freezes quickly. After thawing out
the second stage will not run like it used too, like when the snow is thick the second stage shuts down. Should I adjust something ? Please help...
   / John Deere TRS24 Snow Blower #2
Welcome to TBN. :)
   / John Deere TRS24 Snow Blower #3
:welcome:
Please post in the forum that is closer to help than the member introduction. Maybe the Deere Lawn Garden or Deere Operating would get some others who have experience with the problem.
Sounds like a shear pin.
   / John Deere TRS24 Snow Blower #4
Check your belts, you likely smoked one when it was frozen. Check your clearance between the fan and shroud. Make sure there is no slop in any shafts.
There should be a weep hole there . If not you could add one.
Do you park the machine inside where its heated? That could be a problem. Might want to use fluid film or similar on the chute area to prevent sticking.
Could be a shear on the fan as well as BT suggests.
FORREST RIVER CHEROKEE CAMPER (A52472)
FORREST RIVER...
2016 Chevrolet Tahoe SUV (A52377)
2016 Chevrolet...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A55218)
Ditch Witch 6510A...
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
UNUSED IRANCH EXCAVATOR ATTACHMENT SET (A54757)
UNUSED IRANCH...
