John Deere TRS24 Snow Blower
   / John Deere TRS24 Snow Blower #1
mrouster
My second stage gets snow behind it and freezes quickly. After thawing out
the second stage will not run like it used too, like when the snow is thick the second stage shuts down. Should I adjust something ? Please help...
   / John Deere TRS24 Snow Blower #2
Welcome to TBN. :)
   / John Deere TRS24 Snow Blower #3
:welcome:
Please post in the forum that is closer to help than the member introduction. Maybe the Deere Lawn Garden or Deere Operating would get some others who have experience with the problem.
Sounds like a shear pin.
   / John Deere TRS24 Snow Blower #4
Check your belts, you likely smoked one when it was frozen. Check your clearance between the fan and shroud. Make sure there is no slop in any shafts.
There should be a weep hole there . If not you could add one.
Do you park the machine inside where its heated? That could be a problem. Might want to use fluid film or similar on the chute area to prevent sticking.
Could be a shear on the fan as well as BT suggests.
2014 International ProStar Truck, VIN # 3HSDHSJR1EN768255 (A54865)
2014 International...
KUBOTA M7-152 TRACTOR (A54756)
KUBOTA M7-152...
STORAGE SHELTER KIT (A53843)
STORAGE SHELTER...
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
2013 Great Dane 53ft T/A Reefer Trailer (A51694)
2013 Great Dane...
30pc. 16ft.x 3ft. Black Metal Roof Panels (A53424)
30pc. 16ft.x 3ft...
