John Deere TLB 110
/ John Deere TLB 110 #1
richieg
Long Island new york
John Deere TLB 110
looking to buy a JD TLB 110 anything i should be looking out for that may be common problem. How many hours should that motor last before it needs to be rebuilt.
thanks
Richie G
/ John Deere TLB 110 #2
Welcome to TBN,
The biggest issue is the loader mount bolts, if they where allowed to get loose the bell housing casting would crack.
The Yanmar engine are pretty bulletproof, as are the e-hydro transmissions if they are well maintained.
Hey Kenny that's for reply I am new to JD can you point out where you are talking about would be much appreciated. I like the hooks and the diff peddle going to look at a machine this weekend I will be ordering the hooks and peddle when I get a JD
Thanks
Richie G
/ John Deere TLB 110 #4
I believe there are a few tbn treads about it, but a quick google search should bring good results.
I wish you luck, most 110 owners are quite helpful, so if you have any perspective units, post details.
/ John Deere TLB 110 #5
some cost/expense factors to consider:
-if the tires have been filled with liquid ballast...saves about $300; lots of confusion in blogs about ballast but if you carefully read the JD manual they say 'have it done by a professional/tire store'. Unit has much-improved stability with tire ballast (fyi: also be careful trying to operate without the hoe on the back, way tippy)
-if you are in snow country there is no way to put chains on the rears without wheel spacers...a cost of hundreds of dollars
-side exhaust pipe gets pretty stinky and conversion to a vertical is another few hundred bucks (JD has marks under the hood for the cutout which if used makes a tight job raising the hood so a snug press fit pipe is nice for easy removal)
/ John Deere TLB 110 #6
Deere does not recommend filled tires when using the hoe--extra stress to the out-riggers? I have never heard of a failure, but I had a leaking stabilizer cylinder, without the tires filled.
I think the hardest thing to find is the aux rear hydraulic option--not all have the 7th function on the hoe, but that can be added, with much less difficulty than the 3pair of rear remotes
thanks everybody i pulled the trigger on a 2011 with front and rear hydraulic and 1200 hours nice and clean and tight, spent a little more than i wanted to but it was a local machine so i didn't have to pay shipping paid $28,000 going to pick up on saturday
thanks again
/ John Deere TLB 110 #8
thanks again
Congratulations! Please post pics when you get time.
/ John Deere TLB 110 #9
Congrats. I believe that was the last year they were made.
As someone once said "pics, or it didn't happen.."
yes i think it was the last year i am finding it hard to find a good web site fr OEM parts any info would be appreciated brought it home today i did not have time to play as soon as i get a chance i will post pictures.
thanks
/ John Deere TLB 110 #11
TLB Operators manual page 40: Title: Using Liquid Weight in Tires
No engineering issues with filled tires; just have it done professionally.
“…Avoid injury! Installing liquid ballast requires special equipment…have the job done by your John Deere dealer or a tire service store”.
They go on to address what to fill with etc.
/ John Deere TLB 110 #12
While you can fill the tires for three point use it is not recommended with the backhoe installed. Read all of the details on page 41 and you will see that a 110tlb with the backhoe is not recommended with filled tires. Damage to the drive train can occur. This is clearly stated.
2022 JCB 509-42F TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42F...
3pt 7' Disc Harrow (A64127)
3pt 7' Disc Harrow...
Winchester Sign (A64127)
Winchester Sign...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2018 Ford F-150...
New/Unused ATS Electric Jack (A65583)
New/Unused ATS...
