Disc Harrow john deere pull type disc
/ john deere pull type disc #1
cdupuy
Waco, TX
MF 135, John Deere 4430
Anyone heard of a John Deere off-set, pull type disc that shows a model number 9PK-02 on the nameplate? An online search did not produce any results. The nameplate reads John Deere Killefer Works. The disc needs some new discs, a cylinder, new tires, and some spools. I was hoping to be able to look up some part numbers before I purchased. Attached is a picture of the nameplate, and and overall pic. Any other comments about the viability of bringing this disc back to life are welcome. disc name plate.JPGdisc picture.JPG
Thanks, Carr
/ john deere pull type disc #2
Here's an online parts catalog for the PK offset disc. http://jdpc.deere.com/jdpc/pdfs/PC0843.pdf You can copy and paste the part number to Google, and if an aftermarket supplier handles parts, and happens to add replacing the JD part number, you may find some parts there also. Easiest way to find anything, is to use a part number.
Thanks DJ54. A search for PK is the key. Also updated my location. Thank you.
/ john deere pull type disc #5
I've worked on a disc that looks identical to your pictures. I'm not sure if it's a PK or not, but I'm thinking that a lot of the parts are the same as a 1630 John Deere tandem disc. 1630's are very sought after discs around my area.
Yes, these must be sought after discs here too. this disc sold before I could make a decision to buy. thanks, for all the help. Carr
/ john deere pull type disc #7
i restored a similar type disc, in far worse condition. not a Deere but an Athens Plow. finding parts was relatively easy. i sandblasted the entire thing after dis-assembly and added all new bearings, bearing hangers, disks, and hydraulics, and fasteners. I probably spent $2,000, but the disc is worth far more than that. its a beast! my only caution would be to be sure you have enough tractor. My 75 horse can bearly handle it, and if its wet, forget it. But it works incredibly well
nice work, HCJ tractor. my search continues.....
/ john deere pull type disc #10
Beautiful job HCJtractor! I'm a fan of the smooth blades too. They do a much better job than notched blades. Makes me want my Athens 127 back.
/ john deere pull type disc #11
HCJ, you did a fabulous job on that Athens plow. I used to work for the company that bought them. Athens made great stuff. They even had their own foundry at the plant in Athens, TN.
An offset disc is a lot more aggressive than a tandem disc, and requires a lot more horsepower. But they will really turn the soil much, much better than a tandem disc.
2016 Chevrolet 2500 HD 4WD (A63689)
2016 Chevrolet...
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
2008 Big John 42' Log Trailer (A62613)
2008 Big John 42'...
2022 EZ-GO ELITE...
Four (4) John Deere 8R Front Fenders (A65640)
Four (4) John...
2020 Takeuchi TL8R2 (A64126)
2020 Takeuchi...
