john deere power????????
/ john deere power???????? #1
whitearrow
philadelphia,ms
john deere 5203
i am in the market for a basic agriculture around 50 hp with gears,no shuttle drive.i went and drove the jd 5103 and the dealer said that deere under estimates their pto hp.is there any proof of this?
thanks,
whitearrow->>>--------------->
/ john deere power???????? #2
My 4320 when it was not running correctly Dynoed at 45 at the PTO when it was supposed to be 41 and that was on 3 cylinders for the most part.
Jim
/ john deere power???????? #4
<font color="green"> ...pto hp.is there any proof of this? </font>
Sure - have him demonstrate it on his dyno.
/ john deere power???????? #5
</font><font color="blue" class="small">( In a competive market where specs matter I don't think anyone is going to under rate their equipment. )</font>
I think this has been consistantly proved wrong on TBN for JD, NH and Kubota. I believe that if you go looking you will see many posts that show that when someone actually tests, for instance loaders, that they perform better than the specs would suggest.
Cliff
/ john deere power???????? #6
Loaders can be a little touchy... I think that the ratings aren't just for the brute force that a loader has, but also the amount that can be 'safely' handled, too. For example, while a 210 loader might be able to lift 1000 lbs, it sure would be risky without more mass and wheelbase behind it. The ground that you are on can be a huge factor to this; concrete would be different that uncertain ground.
Just my thoughts - definately subject to verification...
/ john deere power???????? #7
To answer your orig question on PTO HP, advertised vs actual.
If you go to http://tractortestlab.unl.edu/Deere%20test%20reports.htm they have a number of the larger tractor tests performed. They did not do the 5103 unfortunately.
For a 5105:
advertised pto is 45, actual test is 47.15 (at rated 540 rpm)
At rated tractor speed (pto rpm slightly higher), it drops back to 45.85. So looks like they advertise honest numbers, to be honest 2 hp is probably within the error band but it is good they pick a slightly lower number. I am sure with variables in each tractor, they are just playing it safe. 1-2 horsepower either way isn't noticable; to be honest I wish they gave torque ratings on tractor motors and pto, it is a more meaningful to know the torque than HP (torque does the work).
Good luck, you won't go wrong w/ the 5103..
/ john deere power???????? #8
Yes Deere does underestimate their power usually by a few hp. This has been proven time and again on dyno's and at the Nebraska power tests. The dealer that I deal with puts all of their new tractors on the dyno for an hour or more when they get them to make sure they are making the correct power. All the ones I have ever seen have been a couple or more hp above the advertised ratings.
/ john deere power???????? #9
Hi Doc! Glad to see you back! Are you still running all over?
/ john deere power???????? #10
Yes Doc, glad to see you back! Has hay season been running you ragweed??? /forums/images/graemlins/grin.gif
/ john deere power???????? #11
You have to take dyno tests with a grain of salt. Depending on how many HP they are designed to test they can have a pretty large margin of error. I have heard of some odd results when testing small tractors with our 300Hp+ Dyno's.
I also own a load cell. I've tested a handful of tractors of different makes and for the most part each one has tested almost spot on its MFG rating. There is some variation because the relief preasures can be different, but for the most part what they spec is what you should expect.
/ john deere power???????? #12
Yes still running around! Kyle we have been in a drought and our hay has been horrible. Last 300 acre field I did we usually get 900-1200 bales off of it. We got 87 on third cutting. We sold off a bunch of cows this month as we are going to be really short on hay and it's going to be higher than heck this winter.
/ john deere power???????? #13
Richard, I expect that shortage to exist lots of places. Our area is about 7" of rain behind for the year, and now out northwest of the Dallas area, they're having flooding. The rain just isn't getting distributed right this year. /forums/images/graemlins/tongue.gif
/ john deere power???????? #14
Sorry to hear about your hay woes. We have only had less than 2.5" of rain at my place since early June. 5 miles from here has had over 10" in the same period. So some spots have plenty of hay and others not much. I haven't had enough to warrant fertilizing.
Are you getting decent money for your cattle? They are still going for good money down here.
Sorry for hijacking the thread too.
/ john deere power???????? #15
Bird we've been declared a disaster area. We've been in a drought since June.
Kyle cattle prices have been great. We got $1.45 for calves. Our bred cows went for $1778 average for the unregistered ones. We sold a bunch at a big registered sale and they averaged $4320 for bred heifers and $3640 for bred cows.
New Quick Attach Power Spreader (A65579)
New Quick Attach...
Lot of (15) Hedge / Black Locust Posts (A66408)
Lot of (15) Hedge...
12' x 76" Tilt Trailer (A66285)
12' x 76" Tilt...
2021 SANY SY265C LC LONG REACH EXCAVATOR (A63276)
2021 SANY SY265C...
Hanson SB-72 3 Point Snow Blower (A65640)
Hanson SB-72 3...
2014 Club Car Golf Cart (A62613)
2014 Club Car Golf...
