John Deere OEM Easy Change Conversion Kit
/ John Deere OEM Easy Change Conversion Kit #1
melvinhatcher
Maryland
1948 John Deere M and 2016 Kubota L3301
Anyone ever installed the new John Deere OEM easy change conversion kit on the new John Deere Z365r?
/ John Deere OEM Easy Change Conversion Kit #2
Here is one of the video's taking the kit off.
Thank you, I have seen this video. The conversion seems easy enough but, this conversion is done on a lawn "tractor" not a "zero turn". I am aware that the engines are the same, the conversion kit will be the same, the procedure will be the same.
My concern is after the conversion the ability to drain the oil. I don't think the oil drain tube is going to be long enough to drain the oil without making a mess on the chassis of the zero turn.
/ John Deere OEM Easy Change Conversion Kit #4
Most machines these days use an oil drain hose which is usually more convenient and less messy than using the old style drain tube,
You can buy drain hoses on Amazon for pretty much every mower engine around. It would probably make it much easier and less messy when changing oil.
/ John Deere OEM Easy Change Conversion Kit #5
I've also just added a pipe nipple to get the drain out past the frame or other obsticles.
My X584 came with a nice extension with a handy drain valve on the end. The thing they did not do very well was the catch trough beneath the filter. I had to fab up a piece of sheet metal to get that out far enough to avoid mess.
/ John Deere OEM Easy Change Conversion Kit #6
I use a Form-A-Funnel on my X500 oil filter. It tucks right under the filter and then I form the other end to go into a drain pan. They come in different sizes.
Thanks everyone, just the information I was looking for.
/ John Deere OEM Easy Change Conversion Kit #9
Seems the "fault" with the Easy Change system is it doesn't drain the old oil out of the engine completely.
Possible cure is to keep the Easy Change but install a drain pipe in the drain plug hole. Then when changing the filter, just go the extra draining the crankcase.
No mess on the filter side. Just may have to add a bit of oil to fill to the dipstick full mark.
/ John Deere OEM Easy Change Conversion Kit #10
Another possible fault is that it's 50$ for a mediocre oil filter. The price of a new nipple takes care of that.
Hi guys, I bought the John Deere OEM easy change conversion kit and the conversion kit's oil drainpipe is way too short to clear the Z365R's Chassie. Therefore, I purchased the Briggs and Stratton's engine drain hose, which is much longer than the easy change conversion's drainpipe but, still not long enough to clear the Z365R's Chassie and prevent oil spilling on the Chassie or rear tire, while draining engine oil. My challenge now is to find a way to add another three or four inches to my Briggs hose so I could bend the hose to the rear and drain the oil past the chassie.
/ John Deere OEM Easy Change Conversion Kit #12
Hi guys, I bought the John Deere OEM easy change conversion kit and the conversion kit's oil drainpipe is way too short to clear the Z365R's Chassie. Therefore, I purchased the Briggs and Stratton's engine drain hose, which is much longer but still not long enough to clear the Z365R's Chassie to prevent oil spilling on the Chassie while draining engine oil. My challenge now is to find a way to add another three or four inches to my Briggs hose.
Check out Drainzits.
/ John Deere OEM Easy Change Conversion Kit #13
If you would show a pic or two, you likely would get some helpful suggestions to make it work. ;)
Sounds like you are on the right track.
/ John Deere OEM Easy Change Conversion Kit #16
MIU14391 is the oil drain hose for a Z255. Maybe?
I don't know the length of the MIU14391, Z255's engine oil drain hose. However, the Briggs and Stratton oil drain hose #1723165SM is the one I uploaded in my post.
I have decided to try a three-inch 3/8" iron pipe to the oil drain opening on the engine to extend my Brigg's 1723165SM hose to make it longer exit the mower chassis without making a mess when draining the oil
HD Quick Attach Grapple (A66408)
HD Quick Attach...
1/2" Quick Attach Blank Plate (A66408)
1/2" Quick Attach...
2001 Peterbilt 330 4,000 Gallon Water Truck (A64194)
2001 Peterbilt 330...
2007 Freightliner Semi Truck (A66285)
2007 Freightliner...
2018 BOBCAT E50 EXCAVATOR (A65053)
2018 BOBCAT E50...
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
