John Deere LA145 leaking gas
/ John Deere LA145 leaking gas #1
connmj1
Middleburg, Fl
John Deere LA 145
Hello everyone...I'm new to the forum and hope someone can help me. My LA 145 is leaking gas and appears to be from the bottom of the tank. Does anyone know the best way to get the tank out?
/ John Deere LA145 leaking gas #2
Check the fuel line inside the rear of the frame, the tank has a top fuel line outlet so it may siphon the fuel out of the tank and drip if the line is cracked. If not the tank may be cracked. You might be able to lift the rear of the fender pan enough to access the tank after taking off the seat spring bolts.
