John Deere F510 belt problem
/ John Deere F510 belt problem #1
chadhowell
John Deere
The primary drive belt keeps breaking. I have replaced it 3 times. I have also replaced the electric clutch. Anyone know what the problem could be?
/ John Deere F510 belt problem #2
Bad pulleys are capable of destroying belts.
/ John Deere F510 belt problem #3
Try a belt from JD. I has not had any luck with automotive belts on mowers.
Bill
/ John Deere F510 belt problem #4
is pulley running true and not bent? or out of round?
any bad bearings or stiff poits in other pullies it is driving?
soundguy
They have all been jd belts. The pulleys don't appear to be in bad shape nor are the bearings. I think I will replace them anyways.
/ John Deere F510 belt problem #6
i'm not one for fixing what not's broke.. so if they look good and are not binding or catching, and have no sharp bits, and are running rue, i'd look elsewere. don' forget to look a idlers and tensioners..
soundguy
/ John Deere F510 belt problem #7
Replaced the clutch too??
Are you engaging the clutch at the slowest engine speed ... Then increasing the throttle ?? engaging at high speed is tough on belts and clutches .... as you have learned.
One can't feather an electric clutch.
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63688)
2017 Cadillac...
Towable Generator (A60352)
Towable Generator...
Kubota V3600-T-E102 Diesel Engine - Pump Takeout (A63689)
Kubota...
CASE TV370 SKID STEER (A62129)
CASE TV370 SKID...
2023 John Deere 333G Track Loader (A63111)
2023 John Deere...
1996 International Water Truck with a Caterpillar Engine (A63688)
1996 International...
