Buying Advice John Deere compared to Kubota
/ John Deere compared to Kubota #81
My thinking is as follows; If we hold Kubota's proverbial hand to the fire they will tend to improve their product. If we tell them they are great, they will cut more corners. I can live with the treadle pedal, I run a 3410 HST on occasion. But why are the brakes and the travel control on the same side? Cruise control
combined with dual brakes is a recipe for disaster. .
Huh! so over seventy five percent of tractors built today are built wrong!
That would mean that 95% of all tractors ever built are built wrong!!!!!
I guess sometimes there is no logic to some logic!
Kind of like a hand clutch!
/ John Deere compared to Kubota #82
You guys are all unconvincing...I still can't make up my mind this time between JD and Kubota.
Sounds like a draw to me.
I did decide to go up the food chain to a JD3520 or L3940. Right now there are some trade ins still under warranty 1 year left with 225 to 700 hours and...that sounds really good to me.
JD 3520 for 21k; well that is really hard to beat.
/ John Deere compared to Kubota #83
Either of those will do well for you. If you think it is a draw on the tractors then maybe it is down to a financial decision. Go with the one you can get the best deal on. :thumbsup:
/ John Deere compared to Kubota #84
Both are good companies, I have owned both, but I prefer JD. With the current events in Japan, the Kubota brand and parts supply could become an issue. JD has more domestic parts available than Kubota.
/ John Deere compared to Kubota #86
I know they compare those 2 tractors on paper, but IMHO it is comparing apples to oranges. Good luck w/ your decision
What would be a good apples to apples comparison, I am not that familiar with the different John Deere models, thanks.
/ John Deere compared to Kubota #87
in my book you cant compare JD to kubota even if your comparing equally matched tractors.you just need to find a truyjful dealer in both,an ask them both the same qs you want answered.an then decide wich make of tractor you want based on their answers.
/ John Deere compared to Kubota #88
IMHO, As bigbull338 noted - it's tough to make a good comparison. Kubota's L3400 is closer to the Deere 3520 in size & power - but it's far less feature-laden. Comparing the Kubota L3940 to the Deere 3520 - the horsepower comparison is close, but the L3940 outweighs it roughly 700 lbs., has larger tires and physically is quite a bit larger machine. To me a better comparison is the Kubota L3940 to Deere's 4120. They are closer in size, equal features, etc.
/ John Deere compared to Kubota #89
Thanks for the information. All the model numbers sure got confusing when we were shopping for our last tractor. We bought a 50 HP and later an 85 HP, Kubota and John Deere both sure had some nice models.
/ John Deere compared to Kubota #90
One suggestion would be to look around at what folks around you are using. Chances are some of the local farmers and landscapers can be of help. After all, they use the equiptment every day.
/ John Deere compared to Kubota #91
I really need a lighter tractor with more HP. I live on a steep hill. I am leaning real hard to the JD 3520. I need to go drive them both....but it is raining hard this week in Oregon. Can you imagine that? :):):)
/ John Deere compared to Kubota #93
Om21; I think you nailed it. On paper the 3520 appears to be exactly what I need. I am concerned about the comments about it being top heavy. This can only be properly determined by driving the machine.
/ John Deere compared to Kubota #94
Buster57, I have spent limited time on a Deere 3320 and on a Kubota L3240 - there is quite a bit of difference in the feel of each. IMHO, the Deere is more compact and nimble although not as planted and stable on hillsides as the Kubota. Having had 2 tires off the ground on the 3320 while lifting a large 72" pulverizer into a pick-up bed on slightly uneven ground may give me a little skewed view of the Deere.
/ John Deere compared to Kubota #95
I have a 3720 and had the same concern. I'm not someone to go sideways on a hill just to see how tippy it is but I want a tractor that feels planted all the time. I put 4" of wheel spacers on each side in the rear and added fluid to the tires. This stuff was relatively cheap but the riding experience improved a lot. The owners manual told me to add fluid and wheel weights and a ballast box for stability. But, fluid and spacers made all the difference in the world. After 100 hours, I wouldn't hesitate to buy another one.
/ John Deere compared to Kubota #96
Some of the old timers I have spoken to just don't like the new JD compact tractors. Both a neighbor and my FiL both made the same observations, unsolicited.The main complaints I hear from them is the excessive use of plastic body parts and the controls make them more like a car than a tractor. My FiL is kind of hard on his stuff and the plastic on his 3410 keeps getting all broken up. In all honesty, it runs like it was built to mow grass first, and maybe do some other work second. That is just the impression I get. It runs nice and smooth. Lots of power. Just looks and feels like it was built mostly for grounds keeping.
The little Kubota I got (B2620) looks and runs like something I would expect a Japanese farmer to use to plant and work his vegetable or rice fields. It runs like a small farm tractor. In fact, the little B2320 with the narrow front end is absolutely for dirt farming. That is what it was designed for. So, to me, it feels more like a small general purpose tractor. Run a bush hog, pull a small plow, or run a small hay baler. Once, on a lark, I ran my dad's old square baler on his M John Deere. The B2620 may not have as much ground clearance, but it has more weight and horse power than that old M does.
/ John Deere compared to Kubota #97
If someone is sold on JD for whatever reason, the best thing to do would be to find out which manufacturer supplies that model or assembly parts to John Deere and buy it directly from the manufacturer. I think Yanmar (a respected brand) is one of JD's suppliers for example. You should save quite a bit of cash.
Makes perfect sense. By a John Deere direct from the Factory!
/ John Deere compared to Kubota #98
The cab models seem to be a bit tippy...cabs add weight well above the center of gravity. That weight, plus a short wheelbase, can be problematic in some situations.
I have a 4520 with a Curtis cab. I don't think the Curtis cabs are as heavy as the factory cabs. I have a cab since I live in Vermont and our winters can be pretty tough. If I was still in south-central Pennsylvania, I'd still have an open station tractor.
So, if you want less tippy, buy an open station tractor.
As far as Deere vs. Kubota...this has been an ongoing discussion since before I joined TBN (about 16 years ago). I think they're both great...but it seems like the Kubotas are a bit shy on PTO HP compared the the closest Deere equivalent.
/ John Deere compared to Kubota #99
I had never looked at the engine versus PTO HP numbers.
I made three comparisons. Compared percentage of engine HP returned in PTO HP.
Largest was the Kubota M5-111/JD 5100E. JD had .07% better return.
Mid size was Kubota M5-091/JD5085E. JD had 1.6% better return.
Smallest was Kubota MX5200/JD 4052M. JD had .01% better return.
Not sure any of those differences would be noticed.
/ John Deere compared to Kubota #100
This old thread was recently revived, and I can't help but wonder how the tractors from 6 years ago compare to what's being made now.
I also didn't see any mention of how the tractors are made. On my L3240 Kubota, the LA724 FEL pivots were worn when I bought it used, and no bushings were in any of the pivots. I ended up cutting the loader arms apart so I could get them into a mill to bore out the oval holes. Then I turned bushings and installed new pins, and welded everything back together. Major PITA caused by Kubota cutting corners to save a few bux.
The mounts for that same FEL were broken when I got the tractor, and my two attempts to repair them weren't successful. I found other threads on TBN from people with the same issue, so I had a talk with my dealer. He was reluctant to do anything seeing as how the tractor was out of warranty. I showed him the other threads where Kubota admitted there was a design issue, and he was able to get new parts for me but I had to pay something like seven hundred dollars for shipping. The regional service manager he was working with swore up and down there was no design issue, but when the new parts arrived they had been redesigned and the changes were obvious. I was pretty put off by the whole experience, by the lack of help from the local and regional Kubota people, by their implications that I'd somehow mistreated the tractor, and the outright lies they told to cover their butts.
On the other hand, the people in the dealer's shop have been very helpful, showing me exploded parts diagrams and talking me through repairs. I had to split the thing during my first year of ownership to replace a propeller shaft seal (another seemingly common problem with the Ls), and the shop's help was invaluable. That said, the new seal had also been redesigned, an indication, at least to me, that there was another design issue that Kubota wasn't owning up to.
As others have mentioned, the three point on the Kubota is very jerky, and the little set screw thing in the lever slot doesn't do a very good job of bringing the arms to the same position every time. The bracing used to keep the arms from swaying also isn't very strong and it bends easily when pushing dirt backwards with a box blade.
I've also had problems with castings breaking in the front hubs on the Kubota. They just can't seem to take much side hilling. My property is pretty steep, and it's easy to find 20 degree (thats degree, not percent) slopes. The little 32 HP engine has to work pretty hard to keep a 60" rotary or flail mower going up those slopes, and I often have to ease off on the go pedal to maintain engine RPMs. The L3240 is also pretty tippy, even with the tires loaded and the rears set to the widest stance. And the tractor doesn't even have a cab.
I'm not saying these things just to run down Kubota, as they're just my experiences with one tractor at one dealership. I do feel I know a bit more about what to look for in a tractor now, and if I ever feel a need to replace the one I've got, I'll be looking at other colors before coming to a decision on what to buy. And things like bushings and heavy sections for mounts and three points are going to have a big bearing on what I end up with. I think my neighbor, who has a comparably sized John Deer, put it best: These little tractors are good at maintaining stuff, but if you want to build stuff, you need a real backhoe.
Kuhn FC400RG (A60462)
Case Titan 3530 (A63688)
Case Titan 3530...
1062 (A63291)
1062 (A63291)
2020 PETERBILT 367 (A65643)
2020 PETERBILT 367...
2005 CASE 580 SUPER M SERIES 2 BACKHOE (A62129)
2005 CASE 580...
(2) 15.0/55-17 TIRES W/ 6 LUG RIMS (A64280)
(2) 15.0/55-17...
