John Deere Ballast Box
/ John Deere Ballast Box #1
Mark_in_NH
Moultonborough, New Hampshire
New Holland TC35D w/ 16LA FEL
Photos of my new JD GREEN Ballast Box.
1st picture is the box freshly mounted.
This picture is just a rear view of the box. The SMV emblem comes pre attached (big sticker) and covered with a black plastic to protect it. I was pleased to find it, I thought I was going to have to buy one. Saved $8 /w3tcompact/icons/grin.gif
This picture shows the strips of lead weights that I placed in the box. Each ingot weighs 5 lbs. Each strip had 5 ingot for
a total of 25 lbs per strip.
This picture shows the box with all the weight installed. 243 lead ingots with a total weight of 1215 lbs. Add the weight of the box, 88 lbs and the whole assembly weighs in at 1303 lbs.
I may drop it down to 800 lbs to start with and then see if it will be enough.
My JD dealer qouted me a price of $179 for the ballast box, after running the numbers, I got it for $167. All in All, I am very pleased with my new attachment.
As you can see from the last picture it has started snowing here in Moultonborough, New Hampshire. One thing I need to figure out how to do, is to come up with a way to cover the box, to keep weather out. I am open for suggestions.
Enclosed is a picture of my New / Used landscape rake with the New gauge wheels attached, $240.00 OUCH /w3tcompact/icons/frown.gif
/ John Deere Ballast Box #6
Mark,
I have a JD ballast box also... paid a buck and half for it. I hope that you didn't have to purchase all of that lead. I used concrete in mine. Total weight is around 500lbs.
To cover and protect it, I just through a piece of plastic over it and park it under the eaves of my house to keep most of the weather off of it. One thing that you may want to consider is to place some thin strips of wood under the box. This does two things. One, keeps it off the ground to prevent some rusting. Two, it allows you to nudge it around if necessary. You will find a ridge on the bottom of the box which can prevent you from moving it around. Especially if you store it on bare ground.
Terry
/ John Deere Ballast Box #7
Ummmmm, Mark. Not sure if your lead ingots are pure or an alloy, but you might want to look at <A target="_blank" HREF=http://www.midwayusa.com/online/productpage.exe/showproduct?SaleItemID=144043&KeyWord=ingots>this</A>. Now that is for pure lead, but you'll notice that it runs a little more than $1.00 per pound. Let's see. Approximately 1000# of lead at even .75 per pound. Can we say "more toys"??/w3tcompact/icons/smile.gif
BTW, depending on what it's alloyed with, most bullet casting alloys that have tin in them are even more expensive.
Hoss
Terry,
Thanks for the suggestions. I like the idea of keeping it off the ground to prevent rust. I got all the lead for FREE, which is why I chose to use it.
I was thinking of cutting a piece of pressure treated plywood a little bigger then the box opening and notch it to go around the top link bracket.
If I get real creative, I will cut another piece to set down in the box on top of the lead and come up with some way to hinge the cover, then the ballast box can double as a tool box.
/ John Deere Ballast Box #11
Dang wish I had friends with spare lead just sitting around
/ John Deere Ballast Box #12
Hmm/w3tcompact/icons/hmm.gif? Does that mean that you're going to get the lead out??/w3tcompact/icons/crazy.gif
/ John Deere Ballast Box #13
<font color=red>I may be better off selling the lead,</font color=red>
Mark,
Only problem with that is your neighbor may want a cut./w3tcompact/icons/smile.gif
Hoss
Hoss,
That wouldn't be a problem at all. This gentleman is one of my clients, I am caretaker of his big lake front home. Very old mansion type place, 5 car detached garage, 2 bay boat house, huge old 8 bedroom, 5 bath house facing the water, big attached Rec room, Mstr. bedroom is the whole third floor attic, probably 20 x 40 overlooking the lake.
$900 to them is a weekend at the golf course.
Nicest people in the world, they treat you more like family than hired help. When and if they ever sell the place, he has given my dad and myself all the contents of the garage including the old Ford with FEL (9n I think) various attachments etc. Who knows if it will ever happen.
/ John Deere Ballast Box #15
Mark, Can you do me a small favor? Will you take a look at your ballast box & measure
from the bottom 3 pt. link pins to the top link connection? I made a box but I think I
put the pins too high up on the box.
------l l-------------measure here
l**********l
l**********l
l**********l to
l**********l
l**********l
l**********l
l**********l
l**********l
l**********l------here
l**********l
l___________l
P.S. You don't want to know how long it took me to make that picture of the box above!
molerj,
You have way to much time on your hands. /w3tcompact/icons/smile.gif
I would be happy to give you that measurement.
In the morning /w3tcompact/icons/smile.gif
Merry Christmas
/ John Deere Ballast Box #17
I added a receiver hitch to my Ballast Box.
molerj
I haven't forgotten to get your measurment. Somehow the day got away from me and before I knew it it was dark.
Hope you had a Great Christmas day.
I will measure the box as soon as I can.
molerj,
I finally got to take the measurement that you requested.
From the CENTER of the TOP PIN to the CENTER of the LOWER PINS is 15 1/4 inchs
Hope this helps.
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2013 Ford F-350 Knapheide Service Truck (A61573)
2013 Ford F-350...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
Arrowquip 8708L-EF8 Portable Cattle Chute (A64047)
Arrowquip...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A64194)
Bush Hog BH317 Rotary Cutter (A64047)
Bush Hog BH317...
