John Deere 990
/ John Deere 990 #1
Rustyrat
Maine
JD 2305 tlb
I have found a 1999 (2000 I think) John Deere 990 for sale with a 430 loader, backhoe, scraper, mower and snowblower. 1100 hours. He wants 20K. Thoughts?
/ John Deere 990 #3
Great tractor, the 990.
Price is a bit salty, but he does have a lot of implements. And that backhoe (if Deere, it should be a 47 or 48) does add a lot.
/ John Deere 990 #4
That's alot of stuff to keep busy with for quite a spell!! :thumbsup: I believe that the 990 comes with the 8B hoe which is a very HD hoe with the 4-point underframe mount that is very sturdy and durable.
The 430 FEL is a better loader than the earlier model 80 and 440. About 300-400lbs better lift capacity.
What type mower - finish or brush hog? JD snow blower?
Not a great price but not terrible given all the goodies. Give it a good look over and see if the guy will let you test the equipment out - at least - run stuff and check out whether things work as their supposed to.
AKfish
/ John Deere 990 #5
Might be a little high for 1100 hrs.
Great tractor though my friend has one and I use it all the time, just make sure you can live with the non-syncro tranny.
Rob
/ John Deere 990 #6
sounds a little high to me i have one with a hoe it is very heavyduty the only thing is its hard to put on. lining up the slots under the tractor have to be perfict .
/ John Deere 990 #7
AKfish
Yep, you're correct and I was in error.
/ John Deere 990 #8
I missed that too Roy!
The 8B is a little beefer, only small hoe with more power is the 485 (48).
Rob
/ John Deere 990 #9
Make sure you run the unit yourself - in backhoe mode for sure, as the 8B on a 990 tends to be a tad slow moving. It is not a problem for most, but if you are familiar with big hoes, it will seem slow to you. Also, as another poster stated, make sure you are OK with the tranny on it as well. IMO - 20K is a little high, I would want to purchase that package at around 18K, maybe 19K if everything really looks top notch. Good luck!
2011 Nissan Murano SUV (A64557)
2011 Nissan Murano...
2005 Oskkosh MK48A1 8x8 Articulating Tactical Truck w/ MK14 20ft. Flatbed Container Hauling Trailer (A66736)
2005 Oskkosh...
2015 International ProStar T/A Wet Kit Day Cab Truck Tractor (A66736)
2015 International...
2003 Proclaim Tanker Trailer (A64194)
2003 Proclaim...
2022 Kubota SVL75-2 (A64911)
2022 Kubota...
11.2-24 Tires - Set of 4 (A68134)
11.2-24 Tires -...
