John Deere 970 Power Beyond Kit Problems
   / John Deere 970 Power Beyond Kit Problems #11
Where's the pb port???? Is it on the front under a plug or how do I find out where
   / John Deere 970 Power Beyond Kit Problems #12
There is no loader...this tractor had absolutely no hydraulics on it before I put said pb on it ....put lines on as directions told me to nothing with sleeve or plug...kinda on my own here jd dealership is not very helpful since they didn't put kit on.....thanks for all help...ill be tearing into tractor tomorrow and we will see what we see I guess
   / John Deere 970 Power Beyond Kit Problems #13
Sorry, I misunderstood exactly what is happening, and there are two people with same tractor.
Apparently you have nothing except the 3pt, and you want to add a rear valve,and use what JD calls a PB port, which probably comes directly from the pump to the side of the tractor..
I believe there are some ports on the side of your tractor that you have to add your kit to. If you followed the directions, it should work.
You have to provide a flow path for the fluid from the pump to the tank, and by adding the kit, and valve assembly, correctly, you will achieve that .
Your JD manual should indicate the correct ports for the kit.
I am thinking you will have a hose from the side of the tractor to the new valve, and a hose from the valve to the side of the tractor.
Does the new valve use two or three hoses to connect it to the tractor?
   / John Deere 970 Power Beyond Kit Problems #14
The plug I'm talking about goes into the rock shaft housing after you change the new hard line that came with the kit. If I remember right there was 2 plugs on the back side of the rock shsft (3pt valve) and only one would take the plug. It was in my manual, but was hard to understand the manual.
   / John Deere 970 Power Beyond Kit Problems #15
were did you find the power beyond kit for your 970?? and could you give me the part number if you have it..
   / John Deere 970 Power Beyond Kit Problems #16
I got it at jd dealer I think part number is BM18010
   / John Deere 970 Power Beyond Kit Problems #17
How the heck did you pull that off?? my deere dealer tells me that kit number is no longer available.. even purchasing the parts seperate there telling me one of the needed lines is no longer available??
I just wasted $100 bucks to find that the rubber hydraulic hoses are too big to fit between the fuel tank and not interfere with the movement of the rear hydraulics. just not enough room to make it work
   / John Deere 970 Power Beyond Kit Problems #18
do you want to sell that 3rd line you got in the kit... the one that would go to an scv valve if you had FEL.. thats the hard line that deere says is no longer made.
   / John Deere 970 Power Beyond Kit Problems #19
Let me find it. But yeah I have no problem selling it it you
   / John Deere 970 Power Beyond Kit Problems #20
let me know what you want and shipping. just to be clear it is part number AM877598 not sure if what you have will have a part number.. But if the line is outta bm18010 and you have no scv then this would be the only extra line you'd have
2017 MACK CHU613 TANDEM AXLE SLEEPER (A51222)
2017 MACK CHU613...
377811 (A48836)
377811 (A48836)
LOOK! (A50657)
LOOK! (A50657)
2012 Case IH Patriot 3330 Self Propelled Sprayer (A50657)
2012 Case IH...
2014 VOLVO VNM DAY CAB (A51222)
2014 VOLVO VNM DAY...
2015 MACK GU713 (A50854)
2015 MACK GU713...
