John Deere 970 Power Beyond Kit Problems
   / John Deere 970 Power Beyond Kit Problems #1
Deck III
Good afternoon everyone,
I have been searching this forum for answers on the Power Beyond kit I installed. I do not have a FEL on the tractor and plan on installing a dual valve in the rear of the tractor off of the PB. My problem is with the PB installed I do not seem to have control of my 3pt hitch. Any help would be greatly appreciated.
   / John Deere 970 Power Beyond Kit Problems #2
How do you have the system plumbed. What is the logical order of the flow? The 3pt valve should be the last valve in the path.
Show pictures.
   / John Deere 970 Power Beyond Kit Problems #3
What kind of PB did you install in the FEL valve. Some PB adapters have a hex screw that screws in the PB port and blocks off the flow to the tank port. Other PB adapters, you screw the adapter in the PB port and it blocks off the flow to the tank port. If you did not install the PB adapter, the flow is just flowing to tank via the FEL valve tank port.
If the PB adapter is installed correctly, the flow will flow to the 3pt and than tank. If you want to install more valves, you interrupt the flow to the back and feed the new valves and then route the fluid to the 3pt.
Most tank port out flows go to tank, and can be teed in for convenience.
   / John Deere 970 Power Beyond Kit Problems #4
If it is like the 950's there is a pipe plug (that should of came with kit) that has to be put in. Check your manual. I can't explain just where it goes, just to long ago to remember.
Thanks for the info., Hopefully the plug is the problem, will put it in and see what happens.
It was the plug, thanks for the info. really appreciate the help.
   / John Deere 970 Power Beyond Kit Problems #8
Thanks for answering back with the fix.
If it vibrates out, you will lose everything past that point. The FEL will still work.
   / John Deere 970 Power Beyond Kit Problems #9
Hello I'm new here...just read article having same problem. So were exactly does this little 1/4" plug go???
   / John Deere 970 Power Beyond Kit Problems #10
If you have the hex screw for the PB, then is screws inside the PB port. Use some Loctite red or blue to secure it..
Looking at all the valves, some of the valves use a PB adapter sleeve and others use the hex screw.
What this does is to separate the galleries so the main fluid will pass through the valve to another valve, and the cyl used fluid will go to tank. .
As an example, look at page 5, and 9
http://www.princehyd.com/Portals/0/products/valves/LVManual.pdf
2013 JOHN DEERE 470G LC EXCAVATOR (A51242)
2013 JOHN DEERE...
2019 CATERPILLAR 289D SKID STEER (A51242)
2019 CATERPILLAR...
1999 Toyota Tacoma Pickup Truck (A50323)
1999 Toyota Tacoma...
2023 AVANT 735 COMPACT WHEEL LOADER (A51242)
2023 AVANT 735...
2018 KUBOTA SVL95-2S SKID STEER (A51242)
2018 KUBOTA...
Unused Delta Crash...
