John Deere 955 rough idle
/ John Deere 955 rough idle #1
Dirtdeere
California Ag Valley Greenbelt
All Ag, 4 kubotas, 6 deere, reapers, harversters, threshers, hoes, etc
Help! All of a sudden my 955 idles super rough. It takes a while to get it up to high rpms also. It sounds ok when it's revved higher but it is severely lacking in power. I replaced the fuel filter and bled everything and it's still kaput. Any ideas? Thanks. I feel like something is seriously amiss when my tractor is sick!
/ John Deere 955 rough idle #2
It was running rough, you changed the filter and it still runs rough?
/ John Deere 955 rough idle #3
Check amount of fuel flow from tank to inj pump. Is tank venting????? I feel like something is seriously amiss with your profile photo!:thumbdown:
ya I changed the filter thinking that was it and it still runs rough. I just drained the tank and put fresh fuel in it and it still runs rough . What next?
/ John Deere 955 rough idle #5
I would try changing my profile pic for starters.
/ John Deere 955 rough idle #6
Is she the operator ,could explain loss of power .There are special cases out there , and you are in the top 40 .
/ John Deere 955 rough idle #9
It sounds like you may have a bad injector. Try loosening the line at each injector one at a time while engine is running. On a good injector, the engine should run noticeably rougher or even stall. On the bad injector, you won't notice any difference.
2023 Case TV380 (A62177)
2023 Case TV380...
2018 AUTOCAR XPEDITOR GARBAGE TRUCK (A63276)
2018 AUTOCAR...
Ford 8600 (A64127)
Ford 8600 (A64127)
Mini Skid Steer (A60352)
Mini Skid Steer...
John Deere 4955 Tractor (A66285)
John Deere 4955...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
