John Deere 955 rough idle
/ John Deere 955 rough idle #1
Dirtdeere
California Ag Valley Greenbelt
All Ag, 4 kubotas, 6 deere, reapers, harversters, threshers, hoes, etc
Help! All of a sudden my 955 idles super rough. It takes a while to get it up to high rpms also. It sounds ok when it's revved higher but it is severely lacking in power. I replaced the fuel filter and bled everything and it's still kaput. Any ideas? Thanks. I feel like something is seriously amiss when my tractor is sick!
/ John Deere 955 rough idle #2
It was running rough, you changed the filter and it still runs rough?
/ John Deere 955 rough idle #3
Check amount of fuel flow from tank to inj pump. Is tank venting????? I feel like something is seriously amiss with your profile photo!:thumbdown:
ya I changed the filter thinking that was it and it still runs rough. I just drained the tank and put fresh fuel in it and it still runs rough . What next?
/ John Deere 955 rough idle #5
I would try changing my profile pic for starters.
/ John Deere 955 rough idle #6
Is she the operator ,could explain loss of power .There are special cases out there , and you are in the top 40 .
/ John Deere 955 rough idle #9
It sounds like you may have a bad injector. Try loosening the line at each injector one at a time while engine is running. On a good injector, the engine should run noticeably rougher or even stall. On the bad injector, you won't notice any difference.
2017 Ford Escape SUV (A61569)
2017 Ford Escape...
2014 Dodge Charger Sedan (A61569)
2014 Dodge Charger...
UNUSED KJ 25'X12' LIVESTOCK METAL SHED (A62131)
UNUSED KJ 25'X12'...
2015 Ford F-350 4x4 Ext. Cab Pickup Truck (A61568)
2015 Ford F-350...
BUHLER 2 PRONG BALE SPEAR (A62130)
BUHLER 2 PRONG...
New/Unused Wolverine Ripper (A61166)
New/Unused...
