John Deere 955 rough idle
/ John Deere 955 rough idle #1
Dirtdeere
California Ag Valley Greenbelt
All Ag, 4 kubotas, 6 deere, reapers, harversters, threshers, hoes, etc
Help! All of a sudden my 955 idles super rough. It takes a while to get it up to high rpms also. It sounds ok when it's revved higher but it is severely lacking in power. I replaced the fuel filter and bled everything and it's still kaput. Any ideas? Thanks. I feel like something is seriously amiss when my tractor is sick!
/ John Deere 955 rough idle #2
It was running rough, you changed the filter and it still runs rough?
/ John Deere 955 rough idle #3
Check amount of fuel flow from tank to inj pump. Is tank venting????? I feel like something is seriously amiss with your profile photo!:thumbdown:
ya I changed the filter thinking that was it and it still runs rough. I just drained the tank and put fresh fuel in it and it still runs rough . What next?
/ John Deere 955 rough idle #5
I would try changing my profile pic for starters.
/ John Deere 955 rough idle #6
Is she the operator ,could explain loss of power .There are special cases out there , and you are in the top 40 .
/ John Deere 955 rough idle #9
It sounds like you may have a bad injector. Try loosening the line at each injector one at a time while engine is running. On a good injector, the engine should run noticeably rougher or even stall. On the bad injector, you won't notice any difference.
2021 CATERPILLAR 279D3 SKID STEER (A62129)
2021 CATERPILLAR...
New/Unused Quick Attach Pallet Forks (A61166)
New/Unused Quick...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A59823)
2018 FREIGHTLINER...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A62130)
2020 CHEVROLET Z71...
207274 (A52708)
207274 (A52708)
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
