John Deere 955 rough idle
   / John Deere 955 rough idle #1
Dirtdeere
Bronze Member
California Ag Valley Greenbelt
All Ag, 4 kubotas, 6 deere, reapers, harversters, threshers, hoes, etc
Help! All of a sudden my 955 idles super rough. It takes a while to get it up to high rpms also. It sounds ok when it's revved higher but it is severely lacking in power. I replaced the fuel filter and bled everything and it's still kaput. Any ideas? Thanks. I feel like something is seriously amiss when my tractor is sick!
   / John Deere 955 rough idle #2
It was running rough, you changed the filter and it still runs rough?
   / John Deere 955 rough idle #3
Check amount of fuel flow from tank to inj pump. Is tank venting????? I feel like something is seriously amiss with your profile photo!:thumbdown:
ya I changed the filter thinking that was it and it still runs rough. I just drained the tank and put fresh fuel in it and it still runs rough . What next?
   / John Deere 955 rough idle #5
I would try changing my profile pic for starters.
   / John Deere 955 rough idle #6
Is she the operator ,could explain loss of power .There are special cases out there , and you are in the top 40 .
Aw come on! You guys are just jealous!
   / John Deere 955 rough idle #9
It sounds like you may have a bad injector. Try loosening the line at each injector one at a time while engine is running. On a good injector, the engine should run noticeably rougher or even stall. On the bad injector, you won't notice any difference.
2002 Toyota Tacoma Pickup Truck, VIN # 5TESN92N52Z023221 (A48836)
2002 Toyota Tacoma...
2018 Mitsubishi Eclipse Cross SUV (A50860)
2018 Mitsubishi...
1 pallet of power tools (A50860)
1 pallet of power...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A48081)
2000 Thomas Built...
2022 CATERPILLAR 272D3 WHEELED SKID STEER (A50458)
2022 CATERPILLAR...
2015 Ford F-550 4x4 Knapheide Service Truck (A48081)
2015 Ford F-550...
