john deere 770 rear hydraulic outlet
/ john deere 770 rear hydraulic outlet #1
rambaran
I am in the process of adding rear hydraulic ports to my john deere 770 tractor so that I can run a log spliiter or snow blower chute. whilst discussing this with the service manager at a dealership, he said I needed a valve with power beyond so that I can have a line to go from the valve to sump. I have looked at the Scv and there is a line to sump but cannot understand why I would need this line for an open center valve . .. any comments .. thanks
joe rambarna
/ john deere 770 rear hydraulic outlet #2
Didn't see your post until just now. I have a JD790 and added the rear hydraulic kit so that I can run T&T'. If you use the John Deere Kit (I beleive the 770 and 790 are the same in this department) it requires that you you use an open center valve and does not mention any dump to the slump. Since the rear mount kit replaces the pressure line between the SCV and the rock shaft housing you need pressure to pass through the valve and back to the rock shaft housing or your 3 point won't work. In my T&T application everything works as should as long as I do not have two valves in operation at the same time, and I do not have a return to slump. If you have a power beyond valve setup, you would need the return to slump. From what I found out in my research, as long as you are not depending on gravity to return a cylinder, you can plumb through a non-power beyond valve. If you have pressure returning the cylinder, the fluid will force its way though the rockshaft and back to the slump. Since you are looking at log splitter, you need power on both sides on the cylinder so a regular open center valve should work.
Thank you very much for the info. I have all the parts ready, just waiting for a warm day to do the work. I also found some good info on this site 'ag tractor repair' re tractor hydraulics. thanks again
2012 PREMIER 4NNT PORTABLE PUMP (A63276)
2012 PREMIER 4NNT...
2006 Dodge Ram 1500 Pickup Truck (A61568)
2006 Dodge Ram...
DECKED TRUCK BED SLIDING TOOLBOX (A60432)
DECKED TRUCK BED...
Odyssey Pontoon (A62613)
Odyssey Pontoon...
1980 Gleaner F2 with heads (A61307)
1980 Gleaner F2...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01121 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
