John Deere 650 tractor 1986
   / John Deere 650 tractor 1986 #1
Dtanis
1986 john deere 650 tractor
I have a 1986 John Deere 650 tractor. it is currently stuck in 4x4, the shifting handle just free wheels like its not hooked to anything. the roll pin in the handle is good. Can I pull the shaft that the handle is mounted on? I am assuming that the shaft it broken or what ever it was driving is broken. Will pulling the shaft cause any issues.
please advise, thank you
Dan
   / John Deere 650 tractor 1986 #2
I believe you're looking at a split to see much, there's not a lot to the shifter, it's just a matter of getting to it. I have a PDF of the technical manual you're welcome to if wanted, I'll PM you contact info for it
thank you all read got one.
KUBOTA SVL75-3 SKID STEER (A60429)
KUBOTA SVL75-3...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2017 FREIGHTLINER...
2020 CATERPILLAR CB13 SMOOTH DBL DRUM ROLLER (A60429)
2020 CATERPILLAR...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
2010 VOLVO A30E OFF ROAD DUMP TRUCK (A60429)
2010 VOLVO A30E...
48in Forks and Frame Skid Steer Attachment (A56857)
48in Forks and...
