John Deere 60 troubleshooting
   / John Deere 60 troubleshooting #1
Marine2083
Marshalltown Iowa
John Deere 60
Recently bought a John Deere 60. ran fine last fall but now will not start. After charging the battery with leads inverted ( did not see it was a positive ground system)I have replaced the battery and installed it correctly but it will not start. Turns over very slow. Can anyone help me?
   / John Deere 60 troubleshooting #2
Welcome from Wisconsin,post the problem in John Deere forum.
   / John Deere 60 troubleshooting #3
Welcome from VA
   / John Deere 60 troubleshooting #4
Welcome to TractorByNet!
We moved your thread to the John Deere Vintage Tractors forum. :)
   / John Deere 60 troubleshooting #5
It's a basic question, but I have to ask. Are you sure you got a 12 volt battery? Some people are under the mistaken assumption that all 2 cyl JD's are 6 volt. If battery is correct and fully charged, then battery cables, and starter are the only things left in the cranking circuit. Are both of the cables in good shape? Do they have repair ends on the cables? If repair ends are used, be sure to disassemble the ends from the cable and clean that connection.
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
UNUSED MOWER KING ECSSCT72 TRENCHER (A51244)
UNUSED MOWER KING...
Woods 7200 3 pt Finish Mower (A50514)
Woods 7200 3 pt...
2021 CATERPILLAR 299D3 SKID STEER (A51242)
2021 CATERPILLAR...
UNUSED JCT SKID STEER QUCK ATTACH 72" BRUSH CUTTER (A51244)
UNUSED JCT SKID...
