John Deere 5310 transmission
   / John Deere 5310 transmission #1
lawrie
jimboomba, queensland
john deere 5310
My 5310 has power reverser which has developed a problem when going into reverse.
When moved into the reverse position there is a 'mushy' feel as opposed to a solid clunk, and most often it will jump out of gear unless I hold the lever down.
I notice there is an adjustment at the bottom end of the cable where it connects the lever cable to the gearbox.
Does anyone know if this will solve the problem if I lengthen the cable, if so, how far should I adjust it?
   / John Deere 5310 transmission #2
I have a PDF of the Deere Technical manual you're welcome to. I'm sure the answer is in there. Shoot me your email if wanted
Joe
Joe
I have identified the problem, it is a jammed up cable.
I have now removed the cable and I am spraying WD40 into the small gap between cable core and casing, hoping that will dissolve whatever is causing the jamming.
Will let you know when done.
J and L Cargo Express Shadowmaster Enclosed Trailer (A52748)
J and L Cargo...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A52748)
Greenworks...
Yale GLC050LXNVAE087 5,000lbs Propane Cushion Tire Forklift (A51691)
Yale...
20711 (A50323)
20711 (A50323)
2018 Nissan Sentra Sedan (A51694)
2018 Nissan Sentra...
