John Deere 5310 transmission
   / John Deere 5310 transmission #1
lawrie
jimboomba, queensland
john deere 5310
My 5310 has power reverser which has developed a problem when going into reverse.
When moved into the reverse position there is a 'mushy' feel as opposed to a solid clunk, and most often it will jump out of gear unless I hold the lever down.
I notice there is an adjustment at the bottom end of the cable where it connects the lever cable to the gearbox.
Does anyone know if this will solve the problem if I lengthen the cable, if so, how far should I adjust it?
   / John Deere 5310 transmission #2
I have a PDF of the Deere Technical manual you're welcome to. I'm sure the answer is in there. Shoot me your email if wanted
Joe
Joe
I have identified the problem, it is a jammed up cable.
I have now removed the cable and I am spraying WD40 into the small gap between cable core and casing, hoping that will dissolve whatever is causing the jamming.
Will let you know when done.
2005 GMC Sierra Pickup Truck, VIN # 2GTEK13T851399344 (A51572)
2005 GMC Sierra...
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52577)
2018 FREIGHTLINER...
20305 (A51694)
20305 (A51694)
