Snow Blade john deere 5303 2wd ag. tractor
   / john deere 5303 2wd ag. tractor #1
william05
Using John Deere 5305 2wd ag. tractor to plow my driveway. The tractor gets stuck on ice all the time. I would appriciate any suggestions on how to resolve this problem. Thank-you, Will
   / john deere 5303 2wd ag. tractor #2
Tire chains and some extra weight on the back of the machine will do the trick
   / john deere 5303 2wd ag. tractor #3
A bit more information would help some. Did you say you're "plowing" your driveway? What's the purpose for that. IMO I'd use a box blade to cut the driveway if not done already and using the BB create a crown then use a roller to pack it down. I guess I'm a bit confuse by your post.
Richard
   / john deere 5303 2wd ag. tractor #4
Richard
I am thinking he is talking about snow plowing.
   / john deere 5303 2wd ag. tractor #5
That is what I took it to mean...
Chains and weight are the best solution as mentioned.
   / john deere 5303 2wd ag. tractor #6
I figured you did and was only clarifying for the other poster or rather attempting to.
   / john deere 5303 2wd ag. tractor #7
Totally agree with the chains and weight. Maybe slightly lower air pressure too? Don't know if thats doable with R1 or R4 tires.
   / john deere 5303 2wd ag. tractor #8
Welcome to TBN. :)
Gentlemen have given great advice,also try not push full blade until better traction.
   / john deere 5303 2wd ag. tractor #9
My bad. Gotta have snow more often:)
LOAD OUT INFORMATION LOT NUMBER 4 (A53084)
LOAD OUT...
PENDING SELLER CONFIRMATIONS (A52576)
PENDING SELLER...
1999 Case 850G Crawler Tractor Dozer (A51691)
1999 Case 850G...
REIST R25PSS LOT NUMBER 231 (A53084)
REIST R25PSS LOT...
2016 Ford Escape SUV (A51694)
2016 Ford Escape...
2014 FREIGHTLINER CASCADIA DAY CAB (A52577)
2014 FREIGHTLINER...
