Snow Blade john deere 5303 2wd ag. tractor
   / john deere 5303 2wd ag. tractor #1
william05
Using John Deere 5305 2wd ag. tractor to plow my driveway. The tractor gets stuck on ice all the time. I would appriciate any suggestions on how to resolve this problem. Thank-you, Will
   / john deere 5303 2wd ag. tractor #2
Tire chains and some extra weight on the back of the machine will do the trick
   / john deere 5303 2wd ag. tractor #3
A bit more information would help some. Did you say you're "plowing" your driveway? What's the purpose for that. IMO I'd use a box blade to cut the driveway if not done already and using the BB create a crown then use a roller to pack it down. I guess I'm a bit confuse by your post.
Richard
   / john deere 5303 2wd ag. tractor #4
Richard
I am thinking he is talking about snow plowing.
   / john deere 5303 2wd ag. tractor #5
That is what I took it to mean...
Chains and weight are the best solution as mentioned.
   / john deere 5303 2wd ag. tractor #6
I figured you did and was only clarifying for the other poster or rather attempting to.
   / john deere 5303 2wd ag. tractor #7
Totally agree with the chains and weight. Maybe slightly lower air pressure too? Don't know if thats doable with R1 or R4 tires.
   / john deere 5303 2wd ag. tractor #8
Welcome to TBN. :)
Gentlemen have given great advice,also try not push full blade until better traction.
   / john deere 5303 2wd ag. tractor #9
My bad. Gotta have snow more often:)
2019 BOBCAT E42 EXCAVATOR (A52709)
2019 BOBCAT E42...
2010 Dodge Grand Caravan Van (A56859)
2010 Dodge Grand...
Zero Turn Mower (A59231)
Zero Turn Mower...
2015 Chevrolet Express Box Truck, VIN # 1GB3G3CG3F1110762 (A57453)
2015 Chevrolet...
500BBL WHEELED...
Katolight SED60FJJ4 60kW Towable Diesel Generator (A56857)
Katolight...
