John Deere 5300 fuel issues
/ John Deere 5300 fuel issues #1
JoeBob394
Hoschton,Ga
John Deere 5100R
Good morning. I have encountered a recurring fuel issue with my JD 5300. It started with the rpm's increasing on their own, which I understand is a sign of the engine starving for fuel. Shortly after that starts the engine will shut off. I had put a few hundred hours on the tractor before this started happening.
There is a check valve that had been installed in the main fuel line from the tank just before the fuel filter assemble, and I found an inline filter installed in the same fuel line under the tractor that I can not find as being part of the original fuel system. Obviously the previous owner had some fuel system issues.
My hayfield fix was to disconnect the fuel line at the check valve before the fuel filter and blow air back into the tank, re-connect the line after fuel flow was restored, prime the filter etc.
I drained the tank twice during this round of making hay, and strained all fuel going back in the tank. The tank looked clean inside upon visual inspection while empty.
Tractor has performed well until yesterday, while making some round bales. The rpm's surged a couple of times but it did not cut off. You can also notice a change in power output when this happens.
Thats the history, now for the newest discovery. Yesterday evening after making a few bales and having the rpm issue arise again, I noticed it looked a wet like there was a slight leak around the back of the injector pump in the vicinity of the Fuel solenoid and the oil pressure sender (I think that is what it is). The wet substance I noticed is actually like thin jelly, although it smells of diesel fuel.
As you can imagine, I would rather not continue to work on the fuel system in the middle of making hay so any help or advice would be appreciated.
/ John Deere 5300 fuel issues #3
Hey neighbor, I have a PDF of the Deere Tech manual you're welcome to. If wanted shoot me your email
Joe
Thanks DLTTrekkers and joecdeere. There is fuel leaking from the solenoid behind the injector pump. I have ordered the part and will inspect the filter primer diaphragm when I install the solenoid and report back. joecdeere, I have the technical manual but thanks for the offer. I realized early on that it was going to be a necessity.
/ John Deere 5300 fuel issues #5
Hey, any chance I can borrow this PDF boss? I've got a 5300 with the same issue and I'm getting sick of changing the oil when u forget to shut the fuel off.
Thanks!
/ John Deere 5300 fuel issues #6
There is 3 places were the fuel can go to engine oil
1. Thermostart valve. Remove fuelline and blow in it . If you can that valve is faulty.
2. Liftpump. It has a diaphram in it and if faulty it will leak fuel to engine oil.
3. Injectorpump seal .
Well 4. Injectors thats stuck can do that to.
2014 Generac QT04854 Anax 48kW Natural Gas Generator (A61572)
2014 Generac...
JMR mini trailer mover attachment (A61567)
JMR mini trailer...
Tube Line Manure Spreader Nitro 275RS (A63688)
Tube Line Manure...
2025 48in. Farm Jack (A61567)
2025 48in. Farm...
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
LMC Nitrogen Applicator (A62177)
LMC Nitrogen...
