John Deere 5203
/ John Deere 5203 #1
Dickey
Tyro, Arkansas
M5700, L245DT and Mahindra mpower 85
I recently bought 80 acres of mostly pasture land and the man I bought it from had three tractors two of which he has sold. He has a 5203 with 1400 hours on it he is asking 11000 for for it. It's two wheel drive and doesn't have a loader. Is that a good buy and is it big enough? I hope to find someone to cut the hay for the hay but from time to time I may need to bush hog it. I mostly bought the land for an investment and mabe hunt on it a little. I have a Kubota 5700 but I don't want to have to load and move it twenty miles every time it is needed.
Thanks Richard
/ John Deere 5203 #2
It's plenty big enough for bush hogging with a 6 - 8' cutter, but 11 grand is a little steep. That's what I gave for mine with 200 hrs on it. I would be looking more at the $9500 range.
Sent from my Milestone X2 using TractorByNet
/ John Deere 5203 #3
x2
I just bought a nice 2wd 5203 with only 300hrs for $11K. What year is it? (green undercarriage or black?)
/ John Deere 5203
The under carriage is black
/ John Deere 5203 #5
Then the newest it could be would be 2006. I'd shoot for $9-10K. They are good little tractors, I really like mine.
/ John Deere 5203 #6
Here is a JD link that will help you determine the year. If you have not already been to tractordata here is a link to it for specs on the tractor. The last link is an online manual for the 5203.
Have you driven the tractor? This is from tractordata on the trasmission - Three speeds (1-3) plus reverse (R) in three ranges (A-C). Tractor must be stopped, and clutch used, before shifting speed or range. Standard on 2WD models.-
While I do not use my loader much, must admit I am glad I have it. To me if you have a loader you need MFWD. Something to consider.
Model Year of 5000 Series Tractors : What year was my 5000 series tractor built?
TractorData.com John Deere 5203 tractor information
John Deere Ag - New Equipment: Technical Publications - Equipment Search
/ John Deere 5203 #7
Interesting...
"""Have you driven the tractor? This is from tractordata on the trasmission - Three speeds (1-3) plus reverse (R) in three ranges (A-C). Tractor must be stopped, and clutch used, before shifting speed or range. Standard on 2WD models.-"""
/ John Deere 5203 #8
I've got a 2008 5103 and really like it. I too use it for general work around the ranch and have found that I can even use it with my round baler without any problems.
Good luck on your purchase.
/ John Deere 5203 #9
just bought a 2004 5205 with the 521 loader and the 8 speed semi, I would think that the 53 turbo horse power would be enough for almost anything.
/ John Deere 5203 #10
My uncle bought a 5203 with 450 hours 4wd no loader or cab I think 17000 u have to stop to shift nice tractor does pretty much anything only down side is you have to stop to shift
/ John Deere 5203 #11
I have a 5203 and it ran a 7' bush hog through 3" dense brush just fine, even on steep ground. You keep it in A and it will go most anywhere. I think 11k is a fine for 1400 hours if it is in good shape. Ask him if he knows the previous owner and find out a little bit about how he runs things. If he pushes things to the limit but takes good care maintenance wise, I'd get it. If he does light work but none of the fluids have been changed and nothings been greased stay away from it. Just look it over, look for leaks under the tractor, if theres a wet spot, crawl under it and look to see where it's coming from. If it were me I would get it for what you're doing, they're a great little utility tractor and you won't have any problems doing most tasks.
2014 CHEVROLET CAPRICE CAR (A66091)
2014 CHEVROLET...
WEATHERHEAD COLL-O-CRIMP T450-1 HOSE CRIMPER (A64276)
WEATHERHEAD...
2016 Dodge Charger Sedan (A66738)
2016 Dodge Charger...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2012 HIDEOUT BUMPER PULL (A67714)
2012 HIDEOUT...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
