Oil & Fuel John Deere 5045D Tachometer
/ John Deere 5045D Tachometer #1
Ledgemere Farm
Limerick, Maine
A bunch
My tachometer wouldn稚 work until the tractor had sufficiently warmed up. I recently performed the transmission/hydraulic oil interval and now the tachometer works perfectly every time. There was some water in the oil. Coincidence? Does the tachometer have anything to do with hydraulic fluid?
/ John Deere 5045D Tachometer #2
I don't know how that tach works. Could be a bad ground. I have had the flywheel tooth sensor go intermittant on my JD and then quit entirely. Unless the outfit just repaired a ground and charged me for the sensor, but I doubt that.
/ John Deere 5045D Tachometer #3
5045D speed-hour meter has a speed sensor(RE519144) in engine timing gear cover. I seriously doubt changing hyd oil has any affect on speed-hour meter operation.
Deere 333E (A60462)
Deere 333E (A60462)
2019 Mack Granite Tri-Axle Dump w/ Lift Gate 006043 (A62613)
2019 Mack Granite...
1999 John Deere 7810 (A60462)
1999 John Deere...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2025 Future X39 Hydraulic Trencher Skid Steer Attachment (A61572)
2025 Future X39...
(2) UNUSED 420/75R34 TIRES W/ 8 LUG RIMS (A64280)
(2) UNUSED...
