Oil & Fuel John Deere 5045D Tachometer
/ John Deere 5045D Tachometer #1
Ledgemere Farm
Limerick, Maine
A bunch
My tachometer wouldn稚 work until the tractor had sufficiently warmed up. I recently performed the transmission/hydraulic oil interval and now the tachometer works perfectly every time. There was some water in the oil. Coincidence? Does the tachometer have anything to do with hydraulic fluid?
/ John Deere 5045D Tachometer #2
I don't know how that tach works. Could be a bad ground. I have had the flywheel tooth sensor go intermittant on my JD and then quit entirely. Unless the outfit just repaired a ground and charged me for the sensor, but I doubt that.
/ John Deere 5045D Tachometer #3
5045D speed-hour meter has a speed sensor(RE519144) in engine timing gear cover. I seriously doubt changing hyd oil has any affect on speed-hour meter operation.
2000 Sterling L9513 Winch Truck (A63118)
2000 Sterling...
Deutz D3006 Tractor (A62613)
Deutz D3006...
New/Unused Heavy Duty Plate Compactor (A65583)
New/Unused Heavy...
New/Unused Wolverine 3 Point Hitch Attachment (A65583)
New/Unused...
2015 PETERBILT 579 TRI/A DUMP TRUCK (A59914)
2015 PETERBILT 579...
Bandit 250XP Wood Chipper (A63689)
Bandit 250XP Wood...
