John Deere 4720 Rock Bar Lever
   / John Deere 4720 Rock Bar Lever #1
Gerry The Handyman
Bandera, Texas
JD4720
Was using the 3pt when the rock bar lever got real loose. I used to be able to set it at any mid position and it would hold that position. Now it is real loose at any midpoint, it's either all the way up or all the way down. Any idea what I may have broken? Any idea how I can fix it? Thanks in advance!
Gerry
   / John Deere 4720 Rock Bar Lever #2
Gerry, I don't have the answer, but I do have a PDF of the Deere Tech manual you're more than welcome to. I'm sure the answer is in it.
Shoot me your email if you want it
Joe
   / John Deere 4720 Rock Bar Lever #3
There is a friction washer and nut that needs to be tightened. Take a look on JD parts, and you will see the exploded diagram.
2015 Ford Transit 350HD Passenger Van (A50323)
2015 Ford Transit...
2012 CATERPILLAR 304E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
Probst Metal Cart (A50774)
Probst Metal Cart...
19200 (A50324)
19200 (A50324)
2015 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A50322)
2015 John Deere...
2015 John Deere 135G Hydraulic Excavator (A50322)
2015 John Deere...
