John Deere 4720 Rock Bar Lever
   / John Deere 4720 Rock Bar Lever #1
Gerry The Handyman
Bandera, Texas
JD4720
Was using the 3pt when the rock bar lever got real loose. I used to be able to set it at any mid position and it would hold that position. Now it is real loose at any midpoint, it's either all the way up or all the way down. Any idea what I may have broken? Any idea how I can fix it? Thanks in advance!
Gerry
   / John Deere 4720 Rock Bar Lever #2
Gerry, I don't have the answer, but I do have a PDF of the Deere Tech manual you're more than welcome to. I'm sure the answer is in it.
Shoot me your email if you want it
Joe
   / John Deere 4720 Rock Bar Lever #3
There is a friction washer and nut that needs to be tightened. Take a look on JD parts, and you will see the exploded diagram.
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A52128)
Kubota SVL65-2...
1984 NAVISTAR 1954 CABLE HOIST (A51222)
1984 NAVISTAR 1954...
Loader with IH Brackets (A50515)
Loader with IH...
2013 KENWORTH W9 SERIES (A50854)
2013 KENWORTH W9...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
