John Deere 4700 won't go into gear
   / John Deere 4700 won't go into gear #1
al20hp
Jd 4700
I was using my JD 4700 Power Reverser today. However, when moving some wood I heard a "thud" or "clunk" and the tractor would not go in gear. After trying different gear ranges with no success, I put it in 4WD. The front tires moving and I was able to get it back to my house. Also, I had some success using the differential lock. I looked underneath and didn't see anything that looked broken or leaking etc. Any idea where I should start looking? Any advice?
Thanks
Al
I looked underneath and didn’t see anything obvious. I’m taking it to the repair shop tomorrow.
Update
I was at the tractor repair shop and they found the problem.
M808491. Pinion
   / John Deere 4700 won't go into gear #6
Thanks for posting the results found with pictures!
   / John Deere 4700 won't go into gear #7
Can somebody comment further on this, and where this pinion shaft is located?
   / John Deere 4700 won't go into gear #8
Maybe this will help.
   / John Deere 4700 won't go into gear #9
at least it looks easy to get to !
   / John Deere 4700 won't go into gear #10
Beenthere answered your question.
In the future if you open JDparts.com go to PC10440 for model 4700 then enter a part #(M808491)in search window then schematics with part # application locations will appear as shown in photo below.
2012 Ford F-250 Ext. Cab Omaha Service Truck (A50323)
2012 Ford F-250...
John Deere 2755 (A50120)
John Deere 2755...
2014 Freightliner M2 106 Altec DC47T Insulated Digger Derrick Truck (A50323)
2014 Freightliner...
2017 E-Z Beever M12R Towable Brush Chipper (A50322)
2017 E-Z Beever...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2014 Ford F-150...
