John Deere 4700 won't go into gear
   / John Deere 4700 won't go into gear #1
al20hp
Member
Jd 4700
I was using my JD 4700 Power Reverser today. However, when moving some wood I heard a "thud" or "clunk" and the tractor would not go in gear. After trying different gear ranges with no success, I put it in 4WD. The front tires moving and I was able to get it back to my house. Also, I had some success using the differential lock. I looked underneath and didn't see anything that looked broken or leaking etc. Any idea where I should start looking? Any advice?
Thanks
Al
I looked underneath and didn’t see anything obvious. I’m taking it to the repair shop tomorrow.
Update
I was at the tractor repair shop and they found the problem.
M808491. Pinion
   / John Deere 4700 won't go into gear #6
Thanks for posting the results found with pictures!
   / John Deere 4700 won't go into gear #7
Can somebody comment further on this, and where this pinion shaft is located?
   / John Deere 4700 won't go into gear #8
Maybe this will help.
   / John Deere 4700 won't go into gear #9
at least it looks easy to get to !
   / John Deere 4700 won't go into gear #10
Beenthere answered your question.
In the future if you open JDparts.com go to PC10440 for model 4700 then enter a part #(M808491)in search window then schematics with part # application locations will appear as shown in photo below.
Black Galvanized Steel Fencing Kit (A53424)
Black Galvanized...
CAT Skid Steer (A50322)
CAT Skid Steer...
2007 Chevrolet Uplander LS Van (A55853)
2007 Chevrolet...
2013 Great Dane 53ft T/A Reefer Trailer (A51694)
2013 Great Dane...
CATBKTSSL_78 (A55787)
2024 CATERPILLAR 255 SKID STEER (A52705)
2024 CATERPILLAR...
