John deere 455 Questions
   / John deere 455 Questions #11
Remember, I said it takes time to work a few tanks at least! It is not instantaneous! Do you have the mower on it? Do a load test with it on the tractor and the mower engaged. If it stalls/dies then I would look at fuel pump in tank it may be clogged with gunk or pump not delivering the rated fuel needed. If it delivers the rate of fuel needed then it is the fuel injector pump issue. Then I would take it to a diesel shop for a check out.
I have the broom on it right now. Using the shaft on that to get the mid pto reading. Whats the best way to check the fuel pump rate? Can check that tonight and see if its easy.
   / John deere 455 Questions #13
Something that can measure quantity (measuring cup that can hold 2 or 4 cups, plastic, one that will stay in the garage) and a watch with a second hand, stop watch function on some watches or smart phone. Pull hose off at fuel filter (after/before) (in case fuel filter maybe issue) and place into container, turn key.
   / John deere 455 Questions #14
Not familiar with a 455, but does it have an electric fuel pump?
If so, can you hear it clicking when the ignition switch is on?
If you do, put a gauge on the line to the injection pump and check the pressure there.
I you don't have at least 4-5 psi, you have a restriction or plugged filters.
   / John deere 455 Questions #15
Service tech manual for the 455 shows fuel flow test and pressure test.
Well flow is good so that's eliminated. got a message to a parts guy to just get a newer set of injectors and a newer pump (he sells used parts) just going to throw some parts at it and see what happens. maxed the governor out so bad that i blew out the top of the acorn nut that covers it when i put it back on but still not getting bogged down or any black smoke like i think i should be at this point, so gotta replace that when i get to a dealer again. Is there a good place to get a tech manual for this thing? everywhere i look the prices are way high. would be nice to just find a download for cheap. Next i gotta find a heater, cab and snowblower for this thing.
anyone know of an aftermarket fuel pump that i can replace this with. checked used and everyone is out in my area, and the dealer wants 230 bucks for just the pump.
Well I am at 2950 rpms. that 300 rpms is eluding me. pump seems good, the injectors are going to take a bit to clean, and the governor is maxed. replaced the little 2 inch piece of line on the pump because it was pretty shredded but nothing else seems wrong. there is a little nut screw thing on top of the injector pump 90 degrees off from the governor adjustment that I don't know what it is. if anyone knows what does that do? i feel like I am missing an adjustment SOMEWARE just don't know where. Help has been great so far, any more will be greatly appreciated. The parts guy i was talking to is out of injectors so going to run with what I got for now.
the gold colored nut on top is what I am wondering about.
   / John deere 455 Questions #20
According to the manual you have an early style pump, meaning before EPA regs were applied. That gold nut hides the fast idle screw. Remove the nut and under it should be a lock nut with a screw that is adjustable to accomplish the correct high idle, which is 3350 +/- 100 rpm's.
However, I would be concerned with the cause in the drop of rpm's. You didn't give us any history on the machine. No. of hours? Did you acquire it with this problem or has the problem creeped up over time. Is the air filter clean? Forgive me for asking this, but when you adjusted the valves did you know how to properly do it - engine cold, intake and exhaust clearance .008", no lifting action on cam?
Another thing is bleeding the fuel system. This is likely not the problem as much as you have run the machine but its easy. Air can get trapped between the injection pump and the injector. This can happen when you run out of fuel, change the filter, etc. Because air compresses it doesn't get pushed through the injector. With the engine running, crack the fuel line nut at the injector and bleed it (one at a time). It only takes a moment. Start with a cold engine and be careful of obvious fire hazard!
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
2019 MACK GRANITE (A58214)
2019 MACK GRANITE...
2016 Toro Workman HDX-D Diesel Utility Cart (A59228)
2016 Toro Workman...
