Loader John Deere 450C transmission question
   / John Deere 450C transmission question #1
bagreen
John Deere 450C Track Loader
This is an older model (prob. 70s) tractor. I changed the oil in my JD 450C track loader transmission. After that the transmission would pull for a little bit then it slowly stopped pulling. You could let it sit for a little bit and it would pull again for just a few seconds. According to the pressure gauge, it had pressure when in neutral, but shift it into high/low or reverse it didn't have any pressure. Any ideas??
   / John Deere 450C transmission question #2
Welcome to TBN! Everything is tight? Possible air leak? Got foam...?
AKfish
   / John Deere 450C transmission question #3
Welcome to the forum:)
Hopefully poster jd110 will see this thread and help you out. I don't know but it sounds like you have a leak bleeding off pressure to the hydraulic clutch pack. I had a 450A and the tranny never had these problems but had to rebuild the steering brakes and engine. Is this a 450 or 455?
It is a 450C. I am working on tearing it apart to check and possibly replace the clutches. Thanks
More info coming soon! (A55851)
More info coming...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A55851)
2025 Kivel 42in...
AUTO REWIND 12V HOSE REEL (A54757)
AUTO REWIND 12V...
UNUSED Yellow Outdoor Patio Fabric Screen (A53117)
UNUSED Yellow...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
MISC CHAINS (A55745)
