Loader John Deere 450C transmission question
   / John Deere 450C transmission question #1
bagreen
John Deere 450C Track Loader
This is an older model (prob. 70s) tractor. I changed the oil in my JD 450C track loader transmission. After that the transmission would pull for a little bit then it slowly stopped pulling. You could let it sit for a little bit and it would pull again for just a few seconds. According to the pressure gauge, it had pressure when in neutral, but shift it into high/low or reverse it didn't have any pressure. Any ideas??
   / John Deere 450C transmission question #2
Welcome to TBN! Everything is tight? Possible air leak? Got foam...?
AKfish
   / John Deere 450C transmission question #3
Welcome to the forum:)
Hopefully poster jd110 will see this thread and help you out. I don't know but it sounds like you have a leak bleeding off pressure to the hydraulic clutch pack. I had a 450A and the tranny never had these problems but had to rebuild the steering brakes and engine. Is this a 450 or 455?
It is a 450C. I am working on tearing it apart to check and possibly replace the clutches. Thanks
8' LARGE FENCE POSTS (APPROX. 20-25 PC) (A54757)
8' LARGE FENCE...
2012 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTN6 LIGHT TOWER (A55745)
2012 WACKER NEUSON...
2007 PETERBILT 335 LUBE TRUCK (A57192)
2007 PETERBILT 335...
2025 Electric Cart (A55853)
2025 Electric Cart...
2013 FORD F-350(INOPERABLE) (A55745)
2013 FORD...
2025 Swict 72in Bucket Skid Steer Attachment (A55851)
2025 Swict 72in...
