Loader John Deere 450C transmission question
   / John Deere 450C transmission question #1
bagreen
John Deere 450C Track Loader
This is an older model (prob. 70s) tractor. I changed the oil in my JD 450C track loader transmission. After that the transmission would pull for a little bit then it slowly stopped pulling. You could let it sit for a little bit and it would pull again for just a few seconds. According to the pressure gauge, it had pressure when in neutral, but shift it into high/low or reverse it didn't have any pressure. Any ideas??
   / John Deere 450C transmission question #2
Welcome to TBN! Everything is tight? Possible air leak? Got foam...?
AKfish
   / John Deere 450C transmission question #3
Welcome to the forum:)
Hopefully poster jd110 will see this thread and help you out. I don't know but it sounds like you have a leak bleeding off pressure to the hydraulic clutch pack. I had a 450A and the tranny never had these problems but had to rebuild the steering brakes and engine. Is this a 450 or 455?
It is a 450C. I am working on tearing it apart to check and possibly replace the clutches. Thanks
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
Wooden Rocking Chair (A55853)
Wooden Rocking...
2009 FREIGHTLINER M2106 26FT BOX TRUCK (A56138)
2009 FREIGHTLINER...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A57024)
2018 John Deere...
UNUSED X-STAR ACS LOADER BOOM LIFT (A52706)
UNUSED X-STAR ACS...
2022 New Holland C327 Compact Track Loader (A55314)
2022 New Holland...
