DJ54
Elite Member
- Joined
- Jan 20, 2009
- Messages
- 4,698
- Location
- Carroll, Ohio
- Tractor
- IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
We used Tiger teeth on our hoes for a couple of jobs where we were into hard sandrock. Worked great, wore fast. No more than you will be digging though, it shouldn't be a problem.
I am curious as to what you will be doing with the material removed. If it's a bank that is close to the original surface, and the softer brown shale, it should break pretty easy. The problem I see would it may come out pretty slabby. If you're trucking it away, could be rough on a truck bed. If used for fill, it would be tough to get good compaction. Using a larger tractor( D-6 size or larger), it's usually not that big of a deal. Crawl one track up on a chunk, and clamp a brake, or power turn on it, usually crumbles it. On something the size of a 450, it will just bust your kidney's...
We always ripped shale down across the face, from the top, unless using a hoe ( my preferred method
) . But that depends on what you want the end product to look like. Sheer wall at the back, or slope. The steeper the angle of attack, the finer the material will be. Although it seems you always break out hard slabby layer in there somewhere. Just takes a bit to get a ramp built to come down off of..., and that, if a sheer bank already, will come off slabby. Cutting down across the face of the material gives you more breakout force, Your using the power, plus the weight of the machine.
Again that was with a dozer with aggressive corner bits, and you can rip with the corner of the blade, if you hit a tough spot, and kep your cut halfway level. Different story with a track loader...
Just my 2 cents worth...
