John deere 4230 axle seal
   / John deere 4230 axle seal
i try what tx jim says
manuel says you have to remove wheel.
Do you have 5 bolts on the senter of you rim ? 2 Standing out (looks as if it is loose ? Then you have the rachet sisteme to use ! First looses the 3 bolts then screw in that 2 bolts to ******* the wedge then you can turn the bolt on the side to adjust the wheel in or out !
Twisted off one of the three bolts so I cut it out. Wedge will not budge.the bolt that turns out the wheel is frozen
Tight. Put as much force on the two jackoof bolts as I could plus a sledge hammer on the two screw that hold the wedge.I get nothing.
   / John deere 4230 axle seal #13
Try hitting end of axle with a big hammer as recommended by JD or make a pipe to slip on axle that is cut out so it only contacts the wedge that you're trying to loosen.
   / John deere 4230 axle seal #14
Remember to jack-up that wheel ....turn it until the wedge is under........ and remember to remove the c-clip at the end of the axle
My guess would be to have the wedge i want to remove on top or am i wrong?
   / John deere 4230 axle seal #16
WRONG wedge that needs loosened needs to be on the bottom of axle.
|Got her off,took about 20 hits with a sledge on the axle,
thanks guys.
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A51039)
Texas Post Driver...
2020 FREIGHTLINER 26FT BOX TRUCK (A51219)
2020 FREIGHTLINER...
2000 INTERNATIONAL 4300 17FT ROLLBACK TRUCK (A51222)
2000 INTERNATIONAL...
2001 VOLVO A35D WATER TRUCK (A51242)
2001 VOLVO A35D...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
