John Deere 4210 stuck in 4X4
   / John Deere 4210 stuck in 4X4 #1
Tcasteel
Bloomington, IN
John Deere 4210
Just bought a used 4210 that will not disengage the MFWD. Previous owner complained it wore out front tires fast so think this has been going on a long time. Any one have ideas. I have not gotten any manuals yet.
   / John Deere 4210 stuck in 4X4 #2
On that series of tractor, when the MFWD looses power it solenoid default to engaged. Start with checking the fuses. Then look under right floor board for any wires pulled out of the connectors. That is where I would start.
   / John Deere 4210 stuck in 4X4 #3
shoot me your email, I have a PDF of the Deere Tech manual you're welcome to
Joe
Thanks for the excellent information. I finally got enough time off work and found the wires had been pulled apart with a stick and mud still stuck up under that area and had ruined the connector. Rewired it and not will disengage. With back hoe on it did not know PTO was also affected.
   / John Deere 4210 stuck in 4X4 #5
I ended up adding a shield under that area of my 4410. It was just too vulnerable to branches etc.
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
1980 AM General M35A 2.5 Ton 6x6 Cargo Truck (A50323)
1980 AM General...
TMA (A49461)
TMA (A49461)
2010 HEIL TOKEN TRAILER (A52472)
2010 HEIL TOKEN...
2002 International 4300 Truck, VIN # 1HTMMAAN92H547720 (A51572)
2002 International...
LINK BELT LB-98 LOG LINE YARDER WITH MOTORIZED CARRIAGE (A52576)
LINK BELT LB-98...
