John Deere 4210 stuck in 4X4
   / John Deere 4210 stuck in 4X4 #1
Tcasteel
Bloomington, IN
John Deere 4210
Just bought a used 4210 that will not disengage the MFWD. Previous owner complained it wore out front tires fast so think this has been going on a long time. Any one have ideas. I have not gotten any manuals yet.
   / John Deere 4210 stuck in 4X4 #2
On that series of tractor, when the MFWD looses power it solenoid default to engaged. Start with checking the fuses. Then look under right floor board for any wires pulled out of the connectors. That is where I would start.
   / John Deere 4210 stuck in 4X4 #3
shoot me your email, I have a PDF of the Deere Tech manual you're welcome to
Joe
Thanks for the excellent information. I finally got enough time off work and found the wires had been pulled apart with a stick and mud still stuck up under that area and had ruined the connector. Rewired it and not will disengage. With back hoe on it did not know PTO was also affected.
   / John Deere 4210 stuck in 4X4 #5
I ended up adding a shield under that area of my 4410. It was just too vulnerable to branches etc.
2005 Ford F-350 4x4 Service Truck with Crane, VIN # 1FDWX37P55EB97537 (A51572)
2005 Ford F-350...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2019 Ford F-150...
2013 John Deere 2210 Accudepth Field Cultivator (A52349)
2013 John Deere...
2004 FREIGHTLINER CL120 TANDEM AXLE SLEEPER TRUCK (A52577)
2004 FREIGHTLINER...
New/Unused 12ft x 7.4ft x 8.2ft Container (A51573)
New/Unused 12ft x...
