John Deere 420 no spark
   / John Deere 420 no spark #1
jdcrazy1071
Pittsburgh, Pa
420 GT
I have no spark. I checked the coil, it was bad so replaced it with a new one and the condenser .
Coil wires, plugs are good. Does not have points.
She is the P220G model
Any suggestions?
   / John Deere 420 no spark #2
Do you have the TM for the tractor? It is most likely the electronic ignition module/trigger ring buried down under the flywheel. There is a way to test the module in the manual.
   / John Deere 420 no spark #3
   / John Deere 420 no spark #4
here it is as an attachment. this way, it won't get lost from a bad link.
  • Onan Service Manual 965-0762_watermarked.pdf
   / John Deere 420 no spark #5
Follow the instructions on this page. See if you can find the problem.
Richard
Thank you all very kindly. I will try and see if that is the problem.
I will give feed back .
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
2025 GIYI GY-ZWB Hydraulic Backhoe Arm with Tooth Bucket Mini Skid Steer Attachment (A56857)
2025 GIYI GY-ZWB...
KUBOTA X1140 CREW RTV (A52706)
KUBOTA X1140 CREW...
2018 CATERPILLAR 299D2 SKID STEER (A52709)
2018 CATERPILLAR...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
