John Deere 420 no spark
/ John Deere 420 no spark #1
jdcrazy1071
Pittsburgh, Pa
420 GT
I have no spark. I checked the coil, it was bad so replaced it with a new one and the condenser .
Coil wires, plugs are good. Does not have points.
She is the P220G model
Any suggestions?
/ John Deere 420 no spark #2
Do you have the TM for the tractor? It is most likely the electronic ignition module/trigger ring buried down under the flywheel. There is a way to test the module in the manual.
/ John Deere 420 no spark #3
/ John Deere 420 no spark #4
here it is as an attachment. this way, it won't get lost from a bad link.
  • Onan Service Manual 965-0762_watermarked.pdf
/ John Deere 420 no spark #5
Follow the instructions on this page. See if you can find the problem.
Richard
Thank you all very kindly. I will try and see if that is the problem.
I will give feed back .
