John Deere 420 no spark
/ John Deere 420 no spark #1
jdcrazy1071
Pittsburgh, Pa
420 GT
I have no spark. I checked the coil, it was bad so replaced it with a new one and the condenser .
Coil wires, plugs are good. Does not have points.
She is the P220G model
Any suggestions?
/ John Deere 420 no spark #2
Do you have the TM for the tractor? It is most likely the electronic ignition module/trigger ring buried down under the flywheel. There is a way to test the module in the manual.
/ John Deere 420 no spark #3
/ John Deere 420 no spark #4
here it is as an attachment. this way, it won't get lost from a bad link.
  • Onan Service Manual 965-0762_watermarked.pdf
/ John Deere 420 no spark #5
Follow the instructions on this page. See if you can find the problem.
Richard
Thank you all very kindly. I will try and see if that is the problem.
I will give feed back .
UNUSED ATS PA400 ELECTRIC HOIST (A62131)
UNUSED ATS PA400...
(APPROX. 100) UNUSED SDLANCH 6' CORRUGATED STEEL (A62131)
(APPROX. 100)...
FORD DIRT SCOOP (A62131)
FORD DIRT SCOOP...
UNUSED REMOTE CONTROLLED BULLDOZER (A62130)
UNUSED REMOTE...
2014 Keystone RV Outback Camper, VIN # 4YDT21027EB451241 (A61165)
2014 Keystone RV...
20 Yard Roll Off Dumpster (A61166)
20 Yard Roll Off...
