John Deere 410C PLEASE HELP!
/ John Deere 410C PLEASE HELP! #1
PopsGallardo
John Deere 410C
Hello to All,
I have a John Deere 410C 4x4 extend-a-hoe. The driver side axle broke off and I replaced the axle, planetary gears and housing and put it back together and then when I went to drive it in 2 Wheel Dr. it wouldn’t move, I put it in four-wheel-drive and the front tires move then I step on the differential lock and the rear wheels will move so basically my problem is in 2 Wheel Dr. it won’t move, somebody please help me with what it might be. Thank you for your time. I appreciate it.
/ John Deere 410C PLEASE HELP! #2
Welcome to TBN!
It sounds like you broke your differential side and/or pinion gear(s) on the differential. #9, 10
/ John Deere 410C PLEASE HELP! #3
If you don't find your answer here, you might get better exposure on the TBN "Construction Equipment" forum. This Deere forum is mostly ag tractors.
/ John Deere 410C PLEASE HELP! #4
Im agree with Tractor Tech I be checking pinion gears & shafts in the rear differential.
Thank you guys for your replies and information. I appreciate your time and I guess I’ll be dropping the transfer case again! UGH!
/ John Deere 410C PLEASE HELP! #6
I think if that tractor was under my supervision I'd remove rear trans cover for a visual inspection of rear differential.
2016 CHEVROLET IMPALA CAR (A66091)
2016 CHEVROLET...
2012 CHEVROLET SILVERADO 3500HD CC (A67714)
2012 CHEVROLET...
Luck Now 425 (A64911)
2015 John Deere CX15 (A64126)
2015 John Deere...
2012 John Deere 6430 (A64911)
2012 John Deere...
Bush Hog 3815 RR2 (A64911)
Bush Hog 3815 RR2...
