John Deere 410 starting problem
/ John Deere 410 starting problem #1
CTWright
Santa Fe, NM
1959 MF65 Diesel and 1959 Ford 641 gas
Operated the tractor yesterday, today it won't crank over. ran a jumper wire from the starter solenoid and it cranks find so the battery and starter are good. What should I look for next?
/ John Deere 410 starting problem #2
Check neutral start switch located in trans top cover. I've seen where a sealing washer could be removed & old switch reinstalled allowing switch internal contacts to meet better.
it was not the Neutral safety switch. I ran a jumper between the connections and still not cranking via the key switch. The seat safety makes a definite click sound when engaged so I believe I can eliminate that too.
/ John Deere 410 starting problem #4
what about the RIO and PTO switches?. I tried to find the wiring diagram on the web, but all I got was sites trying to make money, or the diagram was NOT for this tractor..
/ John Deere 410 starting problem #5
radios1
Think this is the jd 410 tractor loader backhoe, '71 - '83 vintage.. so likely neither switches are present.
ALLEN AR16 BUGGY (A63569)
ALLEN AR16 BUGGY...
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
26 ft trailer 20 ft bed (A61567)
26 ft trailer 20...
2014 J&M 375ST Seed Tender (A63116)
2014 J&M 375ST...
CASE IH 4230 TRACTOR (A63290)
CASE IH 4230...
2024 Blue Diamond Trencher (A63116)
2024 Blue Diamond...
