John Deere 4005/300cx loader adding dozer
/ John Deere 4005/300cx loader adding dozer #1
gdw55
Hello,
I want to put a dozer/snow blade on my 300cx loader. I have found a like new Grouser 6 way dozer blade 72" but it weighs 1200#. I cannot see just buying a snow blade that sits around 10 mos out of a year when I could really use this all year. Am I out of my mind even thinking this would worl ok on this loader? I can buy this cheaper than any light duty snow pusher. Thanks
/ John Deere 4005/300cx loader adding dozer #2
I'm assuming that it has skid steer universal mounts on it and will be mounted on your 300cx loader. If the weight of the blade exceeds the lifting capabilities of your loader? How will you use it? You will need to lift it at least 12 to 18 inches to make it usable in the dirt and 12 inches in snow.
I have a 66 inch Deere blade that might work for you better. It can easily be converted to a loader mounted blade or adapted to the new style front 3pt hitch to give you a better-stronger blade to push dirt.
Sincerely, Dirt
Here's a couple of pics.
/ John Deere 4005/300cx loader adding dozer #3
I wouldnt really reccomend you put a blade on your loader to move dirt. There will be alot of stress on your loader frame that I would be worried about. Pushing snow is one thing dirt is another. I would go with a frame mounted one for pushing dirt.
/ John Deere 4005/300cx loader adding dozer #4
JDKid, excellent point about the loader mounted blades. I myself don't even like the loader mounted blades for pushing snow,although they are a good cheap alternative for some people.
Sincerely, Dirt
Below pic is a 390 frame mounted blade on JD3520
/ John Deere 4005/300cx loader adding dozer #5
There NO way that is going to work on you loader!
DW-You still have that blade? I could sure use some stuff from it...wish you where closer!
/ John Deere 4005/300cx loader adding dozer #6
Kenney, how about if I deliver it for whatever my round trip fuel cost? I think it would run around 15 cents a mile. Interested?
Sincerely, Dirt
2021 Bell B30E Articulated Dump Truck (A64126)
2021 Bell B30E...
Genie GS-3232 32ft Electric Scissor Lift (A64553)
Genie GS-3232 32ft...
2021 Ford Econoline Box Van, VIN # 1FDWE3FN3MDC22817 (A65563)
2021 Ford...
Hedge Posts (A65640)
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
Anvil (A64127)
Anvil (A64127)
