John deere 3720 question
   / John deere 3720 question #1
Dan Hunter
Platinum Member
Enid, OK
2012 John Deere 3720 eHydro
Whats the diameter on the drawbar hole on the implement side? I don't intend to haul stuff around but merely be able to move my trailer and need to put a ball on it.
   / John deere 3720 question #2
Per JD Parts
Part Number: M123824
Description: Drawbar - DRAWBAR, NA
Specification
Weight: 14.84 LBS 6.73 Kg
Hole Size - Tractor End 0.827 IN
Hole Size - Towed End 1.024 IN
Length 27.559 IN
Thickness 1.000 IN
Width 2.000 IN
No. Holes At "A" Tractor End 3.000 UNITY
Hole Location - Tractor End 1.953 IN
Hole Location - Towed End 1.181 IN
Material 4140
Finish K
   / John deere 3720 question #3
Puzzling to me... seems the Tractor End and the Towed End are the same.. but maybe the Towed End is what I think would be called the Towing End. Putting the ball on the Towing End. :confused2:
   / John deere 3720 question #4
You can verify which end is which by checking the distance from the end to the hole per the specifications.
   / John deere 3720 question #5
Measured mine on the 4300 and the diam is 1 " and the 0.998" threaded end of the 2" ball fits perfectly.
Thanks so much for your efforts. I'm on it.
2021 Chevrolet Silverado 1500 Custom Crew Cab Pickup Truck (A48081)
2021 Chevrolet...
Heavy Duty Plate Compactor (A47371)
Heavy Duty Plate...
2022 Club Car...
John Deere 3pt Cultivator (A49251)
John Deere 3pt...
2022 Club Car...
2015 GENIE S-60X TELESCOPIC BOOM LIFT (A48992)
2015 GENIE S-60X...
